Author Topic: Question on carb rebuild  (Read 1715 times)
Offline tdskip
« on: November 03, 2019, 10:56:55 AM »
 Rebuilding the car was on my 1980 CB 750 F and I’m not sure how deep I should set these needles-is it one turn backed off from tight?
Offline K7-Steppy
Re: Question on carb rebuild
« Reply #1 on: November 03, 2019, 11:03:28 AM »
On my 77 cb750 it is 1 and a half turns backed out from being screwed in all the way. But may be different on dohc
Sent from my Pixel 3 XL using Tapatalk
Offline tdskip
« Reply #2 on: November 03, 2019, 11:33:39 AM »
Thanks -  I know this is embarrassing given that I’m rebuilding these darn things but is that the idle mixture screw?
Thanks!
Offline K7-Steppy
« Reply #3 on: November 03, 2019, 11:48:17 AM »
Air/fuel mixture screw yessir!
Offline tdskip
« Reply #4 on: November 03, 2019, 11:53:11 AM »
Thanks!
Offline K7-Steppy
« Reply #5 on: November 03, 2019, 11:55:35 AM »
Here's a parts list for your bike if that helps
https://www.cmsnl.com/honda-cb750f-750-super-sport-1980-a-usa_model7241/partslist/E++1801.html#.Xb8wfxhMEwD
Offline tdskip
« Reply #6 on: November 03, 2019, 07:38:02 PM »
Thanks.
Well, something went wrong. Got everything re-assembled and back on the bike and it won’t fire. Not even a sputter, which seems to suggest that it’s not getting any air/fuel.  Pretty darn sure that the floats have fuel in them so must be  mixture or the needle. The Pistons were moving in sink in beautifully, so maybe I’ll pull the new mixture screws out and put the ones that were in it back in,  seems odd that 2 1/2 turns out that I won’t be getting some flow.
 I did check and I do have spark.
Offline tdskip
« Reply #7 on: November 06, 2019, 04:26:43 PM »
Put the floats in upside down - oops. Forgot to photo document the before set up and memory (and mechanical skills) failed me.
