Author Topic: Will these rings be OK to use?  (Read 2351 times)
Offline disco
Re: Will these rings be OK to use?
« Reply #1 on: November 05, 2019, 09:58:11 PM »
Yeah I’m sure they will be fine  :D
I’ve run worse than that! 😂
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
« Reply #2 on: November 05, 2019, 11:13:39 PM »
dipped in folgers classic roast!so that's how you free them up?
Offline kerryb
  • Not a very
« Reply #3 on: November 06, 2019, 05:25:20 AM »
Please don't take offense...but how can you tell much from that picture?  I have a similar situation in my future.
« Reply #4 on: November 06, 2019, 06:02:36 AM »
 Should buff right out !
Offline my name is nobody
  • I like Pontiacs and Hondas
« Reply #5 on: November 06, 2019, 06:30:58 AM »
Who's the u-boat commander??...
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« Reply #6 on: November 06, 2019, 06:37:51 AM »
I'd soak them slugs bout a week in some brake fluid, atf mix!
An old diesel mechanic taught me that brake fluid melts carbon!
Offline Pielz
« Reply #7 on: November 06, 2019, 07:03:05 AM »
Boy oh boy check out those cylinder bores! Haha. How long did this thing sit? How neglected was this thing?
Sent from my LG-G710 using Tapatalk
Offline pjlogue
« Reply #8 on: November 06, 2019, 09:38:24 AM »
With all the ferric oxide, the parts ought to bed right in!  Everyone's heard of barn finds but I think this might be a pond find.  LMAO.
-P.
Offline BenelliSEI
  • 1969 cb750
« Reply #9 on: November 06, 2019, 03:43:21 PM »
I hope KerryB realizes you are all “twisting his crank”!
Offline kerryb
  • Not a very
« Reply #10 on: November 06, 2019, 07:10:15 PM »
I knew it was all in fun when someone substituted brake fluid for acetone ;D
« Reply #11 on: November 06, 2019, 07:20:02 PM »
 It was a 10,000 mile engine with 10 oil changes. Then the bike got wrecked and sat in a barn for a couple decades at some point the PO took the carbs off and left it with nothing plugging the manifolds.  I bent my homemade 6 ton hydraulic press trying to press them out and bought a 20 ton Harbor freight one that did the job. I don't think it hurt the block, it might be good to bore at least a few sizes over.
« Reply #12 on: November 06, 2019, 08:09:48 PM »
 I tried rocking the bike, putting a pipe wrench on the dyno, then used a ratchet strap to leave tension on it. As you can see that was one man's folly. The PO loved that bike, maybe why I've worked to save what I can.  I sold front frame parts to a member and it lives on today, at least on paper.
Offline Pielz
« Reply #13 on: November 10, 2019, 07:38:40 PM »
Thanks for the background! I was curious about that.
« Reply #14 on: November 11, 2019, 06:28:03 AM »
Evaporust?
« Reply #15 on: November 11, 2019, 10:04:44 AM »
  The rust was so tight the liquids didn't really get past the top. Evaporust might have eventually worked, even pepsi was suggested. I went with brute force.
Offline pjlogue
« Reply #16 on: November 11, 2019, 12:05:55 PM »
It's a shame for the lack of a few minutes to cover/plug the intakes that damage happened.  Cyls 2 & 3 look like the inside of a cast iron pump that had been stored for decades without being drained.  I'm surprised you didn't punch through the pistons with the press.
-P.
« Reply #17 on: November 11, 2019, 02:02:24 PM »
 I used round pipe to spread the load, there are hammer marks where I tried to pound them out early on. I have other good running cylinders with broken fins. I may try a liner swap if my tig welding doesn't get them fixed. My buddy that welded some fins before at his shop is getting away from automotive. He's seeing fewer working class guys that he likes to work for with good projects and more rich guys that want the moon but never want to pay their bills.
Offline pjlogue
« Reply #18 on: November 11, 2019, 03:29:48 PM »
If you have another set of jugs with good bores you may be able to press the liners out and swap them then do a slight over bore for essentially a new set of cylinders.  I don't know if the ones in the pic can be bored out enough to get rid of the pits.  They look pretty deep.
-P.
