Author Topic: metal shavings in filter  (Read 3450 times)
Offline Randy Nevrotski
  • Randy
  • ITS AUTO-MAD-TIC
« on: November 13, 2019, 11:20:37 AM »
changed oil on my 1976 CB750A with 6750 miles on bike. dirty and had a light silver tint on top of oil. took filter off. it had shinny little pieces of metal in filter. the filter cup had parts missing , flaking off. I sanded down the whole thing. ran bike still had more in new filter. drop the oil pan and its clean. no metal . Then I took left side of motor apart . alt. was clean. took oil pump out then apart. it was in backwards on one side ,motor oil pump. no marks on pump or shaft. 2nd oil pump for trans was also perfect. I put oil pump back together . with all dots right way. drove around then checked filter. just a little bit in filter.                                             what I understand oil go's from pan to pump from pump to filter. am I right about that? I don't know what to check next. when running plenty of oil to rockers. I took cap off            now what should I do        Up Date 9/21/20 I put around 1400. miles on my bike . now i only have a little bit of silver flakes in oil filter ONLY. Never had any in the pan or on top of motor when i had valve cover off to adjust the valves. its not from the trans . the oil that go into trans returns to the oil pan and i never had anything in the bottom of the pan. i put oil press gauge on my bike . its at 50 psi at low idle. when first wearmed up . i change my oil every 400. miles or after a 200 mile round trip down the shore to eat and drink water when my other people who I'm ridding with are drinking a ice cold BEER. i just had to wait till i got home to drink a beer. thanks for all the help. is my oil change too soon or just keep doing it.
« Last Edit: September 21, 2020, 07:58:00 PM by Randy Nevrotski »
1976 CB750A & Other bikes 1980 KZ 650 cafe racer  81 CM400A 82 GS450 79 KZ650 84 NIGHTHAWK 700 77 KZ650 CAFE  87 ZX750R NINJA 2001 KATANA 600 1983 GPz 750 1980 CB750 CUSTOM Past bikes 1974 suzuki GT750 TRIPLE Care Free Custom chopper 117 motor 95 Honda XR650L Dual Sport 87 ZX600R NINJA Honda CB550FOUR 87 Yamaha 225 trike honda 250R trike RM80 HONDA TRAIL CT70
Re: metal shavings in filter
« Reply #1 on: November 13, 2019, 12:31:27 PM »
 If the rockers are oiled and everything appears in order you might just continue to use it. I've had large amounts silver in my race engines filters and three competent engine builders assure me it's normal. However, like you I'm more pleased to see nothing in the filter.
 I would check the cam chain tension to be sure the chain isn't wearing against the cylinder. I've seen a DOHC Honda wear through the cylinder, not a SOHC though.
  • Randy
  • ITS AUTO-MAD-TIC
« Reply #2 on: November 13, 2019, 10:28:45 PM »
but oil pan is clean. anything past the filter will travel throughout the motor . all debris will end up back in the oil pan. that I can figure out if there is a problem its only between oil pick up an oil filter. that I can tell its only the motor side oil pump. .  hondamadic has 2x oil pumps
« Reply #3 on: November 14, 2019, 08:23:47 AM »
 I'm not aware of the trans oil path but my guess would be it's trans related. Hopefully you will be able to find and fix. Sorry I'm not more help.
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #4 on: November 14, 2019, 11:01:01 AM »
As you know, there are two pumps; one for the engine, and one for the transmission.
The filter is place between the engine oil pump and the engine (most of it anyway).  The trans does not receive filtered oil; and the mainshaft and countershaft don't either.
Obviously, the engine oil pump pulls oil from the common sump, so oil in the filter could be from any engine/trans component.  There's not much between the pickup and pump.
« Last Edit: November 14, 2019, 11:12:52 AM by raymond10078 »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
  • Randy
  • ITS AUTO-MAD-TIC
« Reply #5 on: November 14, 2019, 02:12:54 PM »
thanks that's the answer I'm looking for . if I have a problem then its the motor side oil pump. I couldn't find any diagram showing oil path in detail. I'm in Philadelphia it got cold quick. my bike is parked for the winter. I will worry about it in march just in case I have to replace anything then I will have an early start
Offline vik351
  • Adelaide South Australia ...
« Reply #6 on: November 14, 2019, 04:21:32 PM »
Drop the sump and see how much crap is in the corners, then ya would think it's more trans related...???
Yet to drop my sump, had to ride it for a bit first...
next job...
vik...
« Reply #7 on: November 14, 2019, 06:36:49 PM »
Are you sure the metal didn't come from having it in backwards??
  • Randy
  • ITS AUTO-MAD-TIC
« Reply #8 on: November 14, 2019, 11:37:45 PM »
Trying to out pic of OIL pump
  • Moderator
« Reply #9 on: November 15, 2019, 08:06:38 AM »
I scoured the service manual yesterday, and put the (mental) pieces together.  Section 2 of the manual helped - the pic on page 2-8 helped the most.
« Last Edit: November 15, 2019, 08:08:19 AM by raymond10078 »
  • Randy
  • ITS AUTO-MAD-TIC
« Reply #10 on: August 25, 2020, 08:30:53 PM »
update , I haven't did anything to my motor. change oil and very little silver Pisces's in oil
  • Randy
  • ITS AUTO-MAD-TIC
« Reply #11 on: August 26, 2020, 08:19:38 PM »
there wasn't anything on top of motor in cams. the pan was clean. it was only in oil filter and cup. not from trans. i been a mechanic for over 20 years . also can rebuild some automatic transmissions and 5 speeds T5
