Author Topic: 1974 Rickman Honda  (Read 35366 times)
Offline Doug K
Re: 1974 Rickman Honda
« Reply #300 on: February 02, 2021, 01:22:00 PM »
BenelliSei:  I've already added that photo to my Rickman Folder, Thanks.  That gets me wondering if the ebay part is correct for my Bike.  I suspect it was meant to mount a Rickman Fairing to a CB750 frame.  I'm still hoping someone on this site has an original CR mount, and I can thereby modify and then nickel plate the mount offered on ebay. More photos are thus greatly anticipated.
Offline BenelliSEI
  • 1969 cb750
« Reply #301 on: February 03, 2021, 05:24:31 AM »
Doug..... here’s a better photo from the Rickman Facebook pages. Check them out for lots of interesting detail.
The previous owner of my bike is dropping a few bits Friday. He has three fairing side mounts, and a few other small bits h came across. I’ll send photos when I get them.  John D.
« Last Edit: February 03, 2021, 02:48:07 PM by BenelliSEI »
Offline smcgill
« Reply #302 on: February 03, 2021, 01:15:06 PM »
Rickman part # r109 72 507,  same part both sides
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
Rickman CR750 [project in progress]
Offline BenelliSEI
  • 1969 cb750
« Reply #303 on: February 03, 2021, 02:49:01 PM »
[/quot
Thanks Scott..... are they typically horizontal?
Offline smcgill
« Reply #304 on: February 03, 2021, 03:19:54 PM »
John, yes, that picture is turned sideways for some reason.?  If your previous owner keeps coming up with parts, you should be able to start a second bike soon!    Scott M.
 ;D
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
Offline BenelliSEI
  • 1969 cb750
« Reply #305 on: February 04, 2021, 11:33:19 AM »
Stuart (the PO) brought over three lower fairing mounts today. They are aluminum ones they made for the race bike, but he says they copied the originals, that were steel. They look just like Scott’s.
 He also left me the original Rickman clipons, which are great to have. They are drilled and opened up to take the original Honda bar end switches. They even have the small holes drilled for the locating posts in the switches! Perfect!
Now all I need is for the Covid Restrictions to loosen up in Toronto, so I can get into my friend’s shop for brazing up all my new brackets and bits to the frame!
« Last Edit: February 05, 2021, 02:26:14 PM by BenelliSEI »
Offline grcamna2
« Reply #306 on: February 06, 2021, 03:23:54 PM »
Benelli,Did they fashion those brackets out of T6061 aluminum or such ?
Offline BenelliSEI
  • 1969 cb750
« Reply #307 on: February 07, 2021, 03:30:28 PM »
I believe so. The guys on the Rickman Race Team mostly worked in a GM Maint. Shop in Oshawa, Ont.
The pipes are solid, but extremely light. Lots of the big hardware on the bike has been gun drilled and there are many titanium fasteners too........
Offline grcamna2
« Reply #308 on: February 07, 2021, 04:43:04 PM »
Will you be re-attaching all those 75# that you received in that bucket ?
Offline BenelliSEI
  • 1969 cb750
« Reply #309 on: February 07, 2021, 06:03:15 PM »
75#???
Offline grcamna2
« Reply #310 on: February 07, 2021, 08:10:29 PM »
75#???
I'm referring to your reply #280 on pg.12
Offline BenelliSEI
  • 1969 cb750
« Reply #311 on: February 07, 2021, 09:03:05 PM »
75#???
My mistake! 75%. I will use several of the original brackets. Unfortunately, some (like the horn bracket) were probably cut off with a hacksaw and then ground away. They no longer have enough “meat” to reuse, but they made a useful template.
Offline grcamna2
« Reply #312 on: February 07, 2021, 09:28:42 PM »
75#???
your name is John?
John,
I seem to remember that you had said earlier in this thread about fabricating new ones to replace the ones you just described? What type of steel did you use to make them with ?   Bill
Offline BenelliSEI
  • 1969 cb750
« Reply #313 on: February 08, 2021, 06:17:44 AM »
Bill..... several of the brackets I managed to save. Some (like the horn plate that had too much removed when taken off the bike) I made with any steel (matching thickness) I had in my “odd cuts” box. Nothing is structural, all getting re plated, so not too fussy. John D.
Offline grcamna2
« Reply #314 on: February 08, 2021, 10:28:23 AM »
That frame being restored and re-plated is going to look sweet.  8)
Offline BenelliSEI
  • 1969 cb750
« Reply #315 on: February 08, 2021, 02:04:23 PM »
The real issue right now is Covid Restrictions. I’ve got the Rickman on a rolling platform, ready to haul it to a friend’s shop, unfortunately in Toronto. He’s the xpert gas welder and I need a few days of his time...... then a few days of filing and sanding, before the plating. Fortunately I have a few other distractions in the shop!
Offline Doug K
« Reply #316 on: February 12, 2021, 03:19:21 PM »
Dear Benellisei and SMcGill:  Thank you for the photos, and the tip to Rickman Motorcycle Facebook pages.  I'm looking there as well for the elusive front mount.  I'm still interested in purchasing the lower mounts you have if you decide to sell, especially if I'm unable to find a complete set.  I'm enjoying your progress in lieu of any on my project.
Offline BenelliSEI
  • 1969 cb750
« Reply #317 on: February 12, 2021, 06:49:33 PM »
Kind of stalled on this one, but got lots to do on the s/c.
Offline BenelliSEI
  • 1969 cb750
« Reply #318 on: February 13, 2021, 08:43:00 AM »
Nice package in the mail today (very well packed). Sale on EBay a few weeks ago, bought a set of new repro gauges from “scrambler cycle”. Very inexpensive and they look great. Perfect for the Rickman CR.
Offline smcgill
« Reply #319 on: February 13, 2021, 10:05:52 AM »
 I just did the same. purchased from 4>1. The stock speedo froze up and twisted the end off my Motion Pro custom length cable.[I was able to re-crimp]. The repops seem to be of better than expected quality, sized as originals and operate smoothly. I'm happily surprised.
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
Offline BenelliSEI
  • 1969 cb750
« Reply #320 on: February 13, 2021, 10:09:31 AM »
Scott, I  have to agree. They look much better than expected. Look good on your Rickman, for sure. I added some small idiot lights to the mount I built. I think it will be OK!
Did you make new top nuts for your fork tubes? One of mine is pretty scarred.....
« Last Edit: February 13, 2021, 10:12:15 AM by BenelliSEI »
Offline smcgill
« Reply #321 on: February 14, 2021, 08:02:35 AM »
  John, The cap nuts are as I got them. One is a little wrench marked. I imagine they would be tough to source.Greeves in England has the rights to Progressive Metals [O.E.M.], but I doubt they have parts for the 1 5/8" fork. My stem nut was missing, I ended up using a [1950 ish I think] Norton clutch hub nut in stainless. If you find a source for cap nuts, or a reasonable price to machine them, I would love to know!
                                   Scott M.
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
Offline BenelliSEI
  • 1969 cb750
« Reply #322 on: February 14, 2021, 12:08:28 PM »
Scott.... they are fairly complex, with the vent and all. I see on the Rickman Facebook page there are more than a few that would take them. Are yours chromed (mine are)? I have a buddy who could probably make them, but my recent experience with chrome plating quotes leaves me wondering what they would end up costing!!!! I wonder if there are any other 41mm forks that use the same cap?
« Last Edit: February 14, 2021, 06:35:23 PM by BenelliSEI »
Offline smcgill
« Reply #323 on: February 15, 2021, 08:20:08 PM »
  My caps look to be painted silver over the old plating, they aren't all that bad.If a better option presents itself?? I saw your plating dilemma on your other project, [how do you keep finding these deals?]  My recent plating experience was not very good, price or quality.  Scott M.
Scott in Tacoma
cb450 KO [restored]
rz350
Triumph Bonny
Buell M2 [modified]
FLHTK
Offline BenelliSEI
  • 1969 cb750
« Reply #324 on: February 16, 2021, 02:25:24 PM »
I’ll chat with my buddy and see if he wants to make some.... polished stainless maybe?
