Author Topic: 73 Cb500-4 center stand stops not using muffler  (Read 3586 times)
Offline XC204
« on: April 09, 2020, 01:31:05 PM »
I found an easy way to mount stops for the center stand not involving the muffler brackets. I used 5/16 18 bolts longer than stock 2" first on the bolt  is a 5/16 ss washer, a 5/15 ss lock washer, a thick 1/2 " flat washer and a 3/8" ss nut this goes into the top of the center stand clamp holes with a ss nyloc to clamp it . The 5/16" lock washer squeges into the 1 /2" flat washer to center it the 3 /8" nut spaces  the 1 /2" washer ( the stop) to a position that the stand stops parallel to the ground. Works pretty slick all off the shelf. Hope this is useful to someone. Oh I did both sides.
Gary
« Last Edit: April 09, 2020, 05:14:20 PM by XC204 »
Re: 73 Cb500-4 center stand stops not using muffler
« Reply #1 on: April 09, 2020, 01:52:52 PM »
Going to paint it black?
Offline XC204
« Reply #2 on: April 09, 2020, 05:15:33 PM »
I should have powder coated it this morning but I forgot
Offline Scott S
« Reply #3 on: April 22, 2020, 04:27:17 PM »
That's genius.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline XC204
« Reply #4 on: April 24, 2020, 06:11:19 PM »
Thanks I'm not sure if it will need a rubber washer under the big washer though.
Offline JDrider
  • Slowly becoming an uncertified cb550 mechanic
« Reply #5 on: October 20, 2022, 05:04:34 AM »
I was looking for a fix like this, thank you!
JD
1975 CB550K1
