Author Topic: Is this caliper okay to use??  (Read 618 times)
Offline Greyhound
« on: April 12, 2020, 08:18:20 PM »
Got this caliper on eBay to do dual disc upgrade, and noticed the area at the bottom where it looks like it may be damaged.
The notch cutout at the bottom doesn’t look as square and crisp as on my other caliper.
Does this look okay to use??
1977 CB550K3
Re: Is this caliper okay to use??
« Reply #1 on: April 13, 2020, 12:42:55 AM »
Its fine after you have cleaned it all up and got piston out. Probably a hamfisted PO with a big screwdriver prying out the static pad
Offline Bankerdanny
  • Endeavor to persevere
« Reply #2 on: April 13, 2020, 08:16:50 AM »
It should be fine. The pad that side doesn't move within the holder and should also have a cotter pin that keeps it from falling out.
Offline Greyhound
« Reply #3 on: April 14, 2020, 01:48:51 PM »
Gotcha okay great. Indeed when I started cleaning it up, it looked like it was looking better than in the beginning.
Also, can you confirm if the calipers were different on the 550F VS the 550K?
I have a 77 550K, so my second caliper for a dual disc needs to be from a 77-78 550K? Or will 550F calipers fit too?
Or does the second caliper have to be from a 550F?
1977 CB550K3
« Reply #4 on: April 14, 2020, 02:04:45 PM »
All calipers 350f,400f,500f&k,550f&k,450t,500t plus some others are the same
Offline Greyhound
« Reply #5 on: April 14, 2020, 08:06:25 PM »
Ahh okay cool. Thank you.
1977 CB550K3
