Author Topic: Solenoid Clicks  (Read 645 times)
Offline jakec
Solenoid Clicks
« on: April 15, 2020, 09:27:34 AM »
 CB550 stock wiring, starter stopped working mid ride. First attempt to use starter made a "zoot" noise that sounded like low battery. Later attempt made solenoid clicking sound.
Tested battery, 12.6v bike off, 11v bike on (headlight off).
Checked starter switch internals, looks good (rebuilt last summer).
Arced solenoid with screw driver, no reaction from starter.
I removed battery and solenoid so far. Can remove starter motor next. It's likely that the starter motor is the source of the problem, correct? And I can test by setting on the ground and touching the lead to a battery?
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
Re: Solenoid Clicks
« Reply #1 on: April 15, 2020, 09:51:10 AM »
11V..... bad battery
Offline 69cb750
Re: Solenoid Clicks
« Reply #2 on: April 15, 2020, 10:07:07 AM »
Try jumper cables from car to cycle, if starter spins your battery is shot.
Offline BenelliSEI
  • 1969 cb750
Re: Solenoid Clicks
« Reply #3 on: April 15, 2020, 10:11:13 AM »
+1, +1. Battery shot.
Offline jakec
Re: Solenoid Clicks
« Reply #4 on: April 15, 2020, 10:31:16 AM »
What would sufficient voltage be with the key switched on? I have other batteries I can test with.
I can still start and ride the bike and run lights and stuff, just can't use the starter.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
Re: Solenoid Clicks
« Reply #5 on: April 15, 2020, 12:26:25 PM »
Thanks for the responses earlier. I tested with another battery and the starter worked. Is the solenoid still supposed to click when the starter runs?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Solenoid Clicks
« Reply #6 on: April 15, 2020, 05:21:01 PM »
Solenoid should click on 11 volts, that may not turn the starter.
1973 CB 750 K3
10/72 build Z1 Kawasaki
