Author Topic: Gas gauge 61 GMC truck  (Read 1058 times)
Offline Gurp
  • I'm no.......
  • Once was a...
« on: May 12, 2020, 01:47:41 PM »
Stays on full
Thought it was a bad ground.
re grounded the sending unit no change. any suggestions?
new tank and sending unit.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Online jgger
Re: Gas gauge 61 GMC truck
« Reply #1 on: May 12, 2020, 10:21:39 PM »
I believe the sending unit in the tank should put out different voltage as the float are raised or lowers. Maybe  put a multi meter on the output wire and operate the the float by hand. If that gives you a change in the reading then trace the wire to the cluster plus check the guage.
Online scottly
« Reply #2 on: May 12, 2020, 10:46:27 PM »
The sender is a variable resistor, with one end grounded, and the other end connected to the gauge. When the sender is at the empty position, the resistance to ground is high, and the gauge reads empty. When the sender is at the full position, the resistance to ground is low, and the gauge reads full. With the sender wire disconnected, does the gauge read empty?
Online Don R
« Reply #3 on: May 13, 2020, 05:49:26 PM »
Also ground the gas tank float mount? (sender)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #4 on: May 13, 2020, 08:42:52 PM »
even when it was ungrounded it read as full.
Offline BigJimG
« Reply #5 on: May 14, 2020, 12:02:38 PM »
Ungrounded (open), on an old GM truck should read full, shorted sender (zero ohms) will read empty.  To check fuel senders here is the ranges for popular vehicles
Empty - Full
Ford up to 1986 - 73-10 Ohms
Ford 1987 & up - 16-158 Ohms
GM up to 1964 - 0-30 Ohms
GM 1965-1997 - 0-90 Ohms
GM 1998 & up - 40-250 Ohms
Mopar up to 1986 - 73-10 Ohms
AMC 1950-1977 - 73-10 Ohms
Autometer -240-33 Ohms is the most common however other ohm ranges are made
Classic Instruments - 240-33 Ohms (excluding vehicle specific gauge kits which use factory ohm range)
Dolphin - 0-90 Ohms
Dakota Digital - Programmable to work with most Ohm range senders
VDO - 10-180 Ohms
Make sure you're getting proper voltage to the gauges and sending unit.  Its been a while since I've worked on old GM's, but old Mopars (especially trucks) are notorious for the voltage limiter going bad and frying the gauges.
1972ish CB750 Chopper Project
Yet another CB Chopper frame
1972 CL175
1973 CB175
1975 XR75
1975 CB750F
1976 CB750F1
1977 CB750F2
1978 CB750F3  (apparently, now I have a full set...)
1991 XR80
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #6 on: May 14, 2020, 02:12:30 PM »
Thank you Jim this is the info I feel will do me the best!!
