Author Topic: MotoGadget Chronoclassic Speedomtere - RPM setting?  (Read 2039 times)
Offline macvit7906
« on: June 30, 2020, 03:08:07 PM »
Anyone running a motogadget chronoclassic speedo?
So I read the whole manual for the chronoclassic.
You're supposed to splice into one of the coil ground pulse wires and that gets connected to the yellow wire on the chronoclassic speedo to read RPMs.
From there you have to change the RPM setting on the chronoclassic to get it to read the correct RPM depending on 4 stroke vs two stroke, # of cycls and coils.
The RPM setting I need to change is ImpENG, however it does not give the value needed for a 4 cylinder, 4 stroke, two ignition coil engine (CB750)
anybody know know what the setting should be? it goes from 0.25 all the way to 9 in .25 increments. I need the RPMs displayed correctly for start up, tuning, ect.
Any help is appreciated!
Offline macvit7906
Re: MotoGadget Chronoclassic Speedomtere - RPM setting?
« Reply #1 on: June 30, 2020, 08:11:14 PM »
Thank you sir.
You could teach revival cycles a thing or two
