Author Topic: 550 nighthawk triple tree swap.  (Read 1916 times)
Offline Bowman
« on: September 11, 2020, 11:32:23 PM »
I was wondering if I can swap triple tree from a 650 nighthawk to a 550 nighthawk? I want to use the cluster from the 650 on the 550.
Offline Alan F.
Re: 550 nighthawk triple tree swap.
« Reply #1 on: September 12, 2020, 08:04:53 AM »
First post huh, I'll bite.
The short answer is that the 83 CB550SC had 37mm forks while the 83-85 CB650SC had 39mm forks.
You may need to swap more than just the top triple to be able to bolt on the 650 cluster.
Or you can make a bracket to adapt the 650 cluster to the 550 top triple.
Or you can modify the 550 top triple to allow direct mounting of the cluster without an adaptor.
Offline Bowman
« Reply #2 on: September 12, 2020, 08:04:33 PM »
I appreciate that info.
