Author Topic: hydraulic lift table bleeding  (Read 1419 times)
Offline Johnny340
« on: October 09, 2020, 06:01:13 PM »
I'm not sure what brand I have here but it needs to be topped up and bled.  The lift doesn't go all the way up and the pedal only has pressure at the end of its stroke.  I don't see a port on the red ram and assume it's done through the black valve body.  Does anyone know how to bleed one of these?
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
ken65
Re: hydraulic lift table bleeding
« Reply #1 on: October 10, 2020, 11:46:04 PM »
Mine had  the same symptoms but on my jack it had a little rubber bung on top of the jack body. only took about 50ml of jack oil to fix.
Offline BenelliSEI
  • 1969 cb750
« Reply #2 on: October 11, 2020, 06:36:27 AM »
If the cylinder does not have a fill port (rubber plug as described ^^) try the big bolt on top of the pump valve. Fully extend the cylinder, then add small amounts of fluid in there?
Offline Johnny340
« Reply #3 on: October 11, 2020, 01:18:19 PM »
This large hex nut seems to be some kind of bleed port but I haven't been able to fill through it.  I need to replace the seal in the release valve first.  Then maybe filling it up through a hose fitting while extended (overfilling) and letting the excess vent out through that bleed port?
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: October 11, 2020, 04:54:54 PM »
Try fully extending the ram (and hold it there), and then fill through the bleed port?
« Reply #5 on: October 11, 2020, 06:32:04 PM »
 Be sure to block the table in the up position before removing anything.
Offline Johnny340
« Reply #6 on: October 12, 2020, 12:27:43 AM »
Thanks for the replies. Yes blocking it up while working on it was critical. I have it figured it out now. That hex nut is a bleeder and that other silver stud is a check valve that can removed to fill the reservoir. This was missing a copper crush washer and fluid leaked from here. Everything is working well now.
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline BenelliSEI
  • 1969 cb750
« Reply #7 on: October 12, 2020, 07:02:18 AM »
Well done! “instructions are for people that don’t know what they are doing”.
