Author Topic: Be careful when buying the aftermarket filter bolts.  (Read 980 times)
Offline maxheadflow
« on: December 28, 2020, 05:47:20 PM »
I bought this one from 4into1 through Amazon.. The pressure relief valve is crap. The plungers does not fit into the bolt snug enough to block anything and the spring is too weak.
Offline kmb69
Re: Be careful when buying the aftermarket filter bolts.
« Reply #1 on: December 28, 2020, 05:58:09 PM »
Yep, they are junk.
One I bought had the spring pin extending out one side just enough to score the hell out of the filter housing.
Garbage.
Offline jakec
« Reply #2 on: December 29, 2020, 03:32:50 PM »
I'm running one of these on my 750. I've never looked inside one or knew they had moving parts. What is wrong with it?
1970 CB750 K0
1977 CB750 Chop
1984 Big Twin Evo Chop
1997 XR650L
« Reply #3 on: December 29, 2020, 03:40:17 PM »
CCJ - Cheap Chinese Junk.
Offline BenelliSEI
  • 1969 cb750
« Reply #4 on: December 29, 2020, 04:02:03 PM »
Jake.... in theory, if your filter gets totally plugged, the relief valve should allow oil to bypass the element. Light spring pressure, and a poor seal, could allow full time filter bypass. Not a good idea. There were lots of good replacements made years ago, I have one actually “made in the USA”, but some new stuff is crap.
Honda used a 12mm head on the originals, in an effort to prevent over torquing, but usually it was just impossible to remove when too tight... look for a good, used original, and torque lightly.
Offline maxheadflow
« Reply #5 on: December 29, 2020, 06:54:29 PM »
The problem is that with a loose fit of the bypass valve, it can allow crap to pass through the valve instead of the filter.
The main reason why I bought it was that the 12mm head on the stock one was chowdered. (not by me)  I don't have any problem with the 12mm bolt.  While some may over torque, the big issue it that they can stick. A few taps with a brass hammer on the 12mm hex and it always pop loose.  As far as I can tell you can still get OEM Honda bolts but they are about 50 bux.
