Author Topic: handlebar control locating pin Q?  (Read 675 times)
« on: April 02, 2021, 12:36:47 PM »
  Has anyone ever replaced / repaired one? My bike probably had aftermarket bars at some point and the locating pins are missing in the controls.  I tried to pull a pin from a newer control with no luck. Seems to be a design change.
Offline caluser2000
Re: handlebar control locating pin Q?
« Reply #1 on: April 02, 2021, 12:42:07 PM »
I just grind them off or remove them. They are a  nuisance when wanting to swap handle bars. I you want though you can make a locating pin out of a suitably sized role pin.
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
« Reply #2 on: April 02, 2021, 01:09:23 PM »
 I don't like my mirror moving around when it gets bumped.  This just in, I did find an early control with broken clutch adjuster threads, the pin pulled right out, it was obviously pressed in while the newer ones seem to be cast in place. It  is loctited into the left side now.
 Answered my own Q? but I'll leave it for reference   Now to see how many old broken controls I can find, I have at least one more bike like this.
Offline markmyodb
  • Honda owner since 1969. 19 Honda motorcyles, cars, and lawn mowers through the years!
  • Always looking for SOHC people to ride with in NC
« Reply #3 on: April 02, 2021, 01:35:20 PM »
I magic markered the tip of the pin, located it the best I could and drilled a hole in the bars when I fit aftermarket bars on y 550K1. also had to put in holes for cables. a good morning's puttering. I used a close drill to the pin diameter, maybe 0.02 over. Feel like the radial location is off a little, but it is good for me.  The bars I chose were much flatter than the originals.
I tell my wife the motorcycles are an investment...
CB550K1: 1975
CB750K6: 1976
Offline caluser2000
« Reply #4 on: April 02, 2021, 01:58:38 PM »
On my'76 CB550 I dremeled slots into the control blocks so I don't need to feed the looms through the handle bars. You have the make the cutouts big enough the wiring in them does no get crushed and short while screw the two control blocks together.t Set up is rock solid and water proof. Also easy peasy to swap bars if I chose to.
Those dog leg levers make operating the clutch and front a lot lot easier.
« Last Edit: April 02, 2021, 02:29:47 PM by caluser2000 »
« Reply #5 on: April 02, 2021, 03:00:40 PM »
 I'd like a set of those levers for my Hot Rod bike project that's next in line after the gold K0. I went through all of my controls and didn't find any more early lower halves.  I remember saving a pin but it's not in the spot I remember leaving it.
 Keep the tips coming, I appreciate it.
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: April 02, 2021, 03:03:24 PM »
Don.... if you need more pins, I have a box of busted controls. Could probably dig out a few extra.
« Reply #7 on: April 02, 2021, 06:22:34 PM »
Awesome, let me check. I'm sure I could use one or two.
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: April 02, 2021, 08:36:00 PM »
Don.... I will do the same and report back next week. J.
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
« Reply #9 on: April 03, 2021, 04:57:28 AM »
I tapped the hole for m6 threads, and cut the head off of a bolt and slotted it so I could screw it in. Worked great.
