Author Topic: CB550 oversize piston ring source?  (Read 859 times)
Offline TheVet
« on: April 03, 2021, 07:05:28 PM »
Anybody have a good source for extra rings?  Broke the damn middle ring on #3 trying to get the cylinders down tonight and all I'm seeing around short of an entire piston kit are standard size rings.  Working with 0.5 overbore (59mm) pistons from Cruzinimage.
'74 CB550 "Pile o' Parts" (in progress)
'71 CB350 "Project Cafe" (done)
'06 Daytona 675 "Genesis" (track bike)
Offline caluser2000
Re: CB550 oversize piston ring source?
« Reply #1 on: April 03, 2021, 10:22:52 PM »
Did you ask Cruznimage if they can get  at least a single piston set from their supplier?
Every time you set your ass on a bike, you're playing a game of Russian Roulette between yourself and your own stupidity."
« Reply #2 on: April 03, 2021, 10:23:38 PM »
Chance is low if someone here bought extra rings with their kit.
This is the ring, right?
https://www.cruzinimage.net/2017/09/12/honda-cb500f-cb500k-553cc-bigbore-piston-ring/
Too easy to snap a ring or bend an oil rail.
Offline caluser2000
« Reply #3 on: April 03, 2021, 10:46:31 PM »
Yeau. I use hose clamps to hold the in when dropping the block down onto the pistons. You reall onlly need 2 but I prefer to use 4.
Offline TheVet
« Reply #4 on: April 04, 2021, 03:25:27 PM »
Nice!  Did not know cruzin had a standalone store, thought he was Ebay only...  Not jazzed about shipping from Japan since I'm at a standstill until the rings come, but at least they're available.
Found some 59mm rings from Dynoman (right down the road in Austin), not sure if rings are fairly universal and could be used or are they more proprietary to each piston manufacturer?
« Last Edit: April 04, 2021, 03:33:08 PM by TheVet »
« Reply #5 on: April 04, 2021, 03:32:51 PM »
That kit is 550 +0.5 rings and pistons so maybe Dave Silver or elswhere has Honda ones, will be dearer but quicker
« Reply #6 on: April 05, 2021, 12:42:34 AM »
cruzinimage.net is much better than eBay!
Quick support and adjustment of shipping after you have paid with refund. Happened me every time.
The clutch fibers for CB750 work fine. I guess they are OK for other bikes too.
Offline TheVet
« Reply #7 on: April 05, 2021, 05:59:03 PM »
Dynoman CS confirmed that their 59mm rings will NOT fit, for reference.  Will have to wait out shipping from CruzinImage  :-\
