Author Topic: CB750K7 Carb #4 drips  (Read 487 times)
Offline flybackwards
« on: May 16, 2021, 04:43:58 PM »
Just restarted my CB750K7 rebuild with very nice rebuilt carbs from Vintage Carb Shop - bike started right up and runs well - however I have a slow drip from the #4 carb overflow (the fitting on the bottom) as well as an intermittent miss on cylinder 4 - I think the items are linked what do I check next?
Offline jeremyillingworth
Re: CB750K7 Carb #4 drips
« Reply #1 on: May 16, 2021, 04:50:02 PM »
If it's overflowing, there is excess flow.
The first thing I would do is check the float and needle. It may be a case of a small bit of debris keeping it open.
Sent from my SM-G930W8 using Tapatalk
Offline Kenzo1979
« Reply #2 on: May 16, 2021, 04:53:07 PM »
Slow drip sounds like float height or hairline crack in overflow tube.  Steady drip could simply be a stuck float, tap the sides of the carb to free it.
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
