Author Topic: K7 centerstand  (Read 524 times)
Offline kvikgrip68
K7 centerstand
« on: June 14, 2021, 01:30:32 AM »
Hi there
Am i the only one with a center/main stand footpeg  hitting ground at sharp left turns ?
Offline Kevnz
Re: K7 centerstand
« Reply #1 on: June 14, 2021, 03:25:14 AM »
I seriously doubt it! I don't have personal experience with the K7, but have had 3 K2s and they scraped very easily, especially if you are "getting it on". If 2 up or rear springs a bit weak, it will be worse. It's been a while, but IIRC the sidestand touched down first, unless the rear pegs were folded down. If you check out similar bikes, you will probably find the forward ( downward pointing in the retracted position) face of the sidestand will  have a flat ground on it.
Good grammar: The difference between knowing your #$%* and knowing you're #$%*
Offline flybackwards
Re: K7 centerstand
« Reply #2 on: June 14, 2021, 11:30:57 AM »
Don't know never been over that far on mine - maybe a YZF-R6 for you!
