Author Topic: Honda OEM O-ring material  (Read 1259 times)
Offline stocky
« on: June 15, 2021, 01:45:10 PM »
Hey guys, what material are the oem Honda o rings usually made out of? Or does it vary in application?
Looking to replace the o rings on the oil lines on my 77 750k and was wondering if nitrile is good enough in terms of heat? Not really sure how hot that area gets as nitrile has a range of -35°C to +120°C (-30°F to +250°F). Thanks.
Offline Maltboy
  • Pitter-patter, let's git at 'er!
  • Making stupid mistakes since 1959
Re: Honda OEM O-ring material
« Reply #1 on: June 15, 2021, 05:42:07 PM »
I think they used Viton.
Offline Alan F.
« Reply #2 on: June 15, 2021, 05:56:26 PM »
On occasions like these I refer to this page:
https://mykin.com/rubber-chemical-resistance-chart-3
http://forums.sohc4.net/index.php/topic,61168.msg2055020.html#msg2055020
Reply #27678 Pewe states his big bore bike stays below 120C with good quality oil. 120C= 248F
He states stock 750s only see temps of about 105C in the oil tank. 105C= 221F
Looks like you might be ok with Nitrile.
« Last Edit: June 15, 2021, 06:11:54 PM by Alan F. »
« Reply #3 on: June 16, 2021, 12:35:26 AM »
Honda o-rings must all be nitrile.
Viton feels different, more synthetic plastic.
Not as the little sticky rubber surface as nitrile.
I ordered some sizes of viton o-rings from a UK seller for some future rebuilds.
Offline Alan F.
« Reply #4 on: June 16, 2021, 07:14:34 AM »
I've used the Nitrile o-rings in the harbor freight kits with good success for oil and fuel related stuff.
Offline stocky
« Reply #5 on: June 16, 2021, 08:53:50 AM »
Good stuff guys, went ahead and just ordered viton o rings, since I’m replacing the hoses due to a leak, don’t wanna deal with another potential leak down the line.
Offline Kevin D
  • SE Michigan
« Reply #6 on: June 16, 2021, 09:15:22 AM »
Nitrile is ok for medium hot, Viton $$ is good for very hot.
Check your orings near the head gasket, if they’re at all crunchy, get viton.
We used nitrile and viton interchangeably on 10000amp main unit transformer bushings, very hot. The viton fared better but the short sighted boss didn’t want to spring for it.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Maltboy
« Reply #7 on: June 16, 2021, 11:58:15 AM »
If you ever want a complete set of o-rings, there's at least one SOHC member who has some kits. I bought one from him and they are very nice, and he's a great guy to do business with.  He even has the washers for the oil hoses and drain plug. There may be other members who sell them as well.
This community is amazing.  I'm also a member of an MG forum, and a lot of those guys are total a-holes.
Offline stocky
« Reply #8 on: June 16, 2021, 12:25:42 PM »
Why didn’t you say so earlier, coulda saved me the headache lol, need names of these members please.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: June 16, 2021, 04:36:39 PM »
+1000 for this forum, best there is.
1973 CB 750 K3
10/72 build Z1 Kawasaki
