Author Topic: Need help with carbs  (Read 955 times)
Offline Que75cb750
« on: July 02, 2021, 01:09:17 PM »
I see very little info about these carbs or at least I can’t find what I’m looking for. This is the one part of the bike that I have very little knowledge about. If you see in the picture the “air screw” has a stopper that only lets me turn it a max of just under one full turn. I’m not even sure if this is the proper screw but I read that it should be lightly turn in to stop then out x number of turns, also this has the mechanical arm which operates all the carbs, not individual cables to each carb so if I was to use a vacuum gauge to sync the carbs this is where I adjust the needle in or out ?? The bike runs pretty good, pops a lot on deceleration, I did try pods at one point but ran like crap so put back the air box since my limited knowledge of carbs kind of scared me off playing around with them. There is quite a bit of chain rattle at idle which maybe syncing would help. My plan is to tear the motor apart this winter to freshen it up, burns some oil, oil from oil tank leaks in to motor when sitting for a while, change cam and primary chains etc but I would like to know how these carbs work and what screw does what so I can tinker with it this summer and before I tear it apart. I realize these are fairly simple carbs but it’s something I’ve never taken the time to learn about so any info on these particular carbs would be great. Thanks in advance.
Offline WhyNot2
  • I'm finally an
Re: Need help with carbs
« Reply #1 on: July 02, 2021, 02:26:26 PM »
What year, what model carbs, and what bike......appear to be cb750 carbs.......?
Won't be able to help much, as I'm in the middle of having carbs issues too......!!!!!!
Offline Que75cb750
« Reply #2 on: July 02, 2021, 05:50:18 PM »
It’s a 75 750f I have never seen the stoppers on the the air screw.
Offline newday777
« Reply #3 on: July 02, 2021, 06:22:44 PM »
Stu
My current rides
Prior bikes....
Offline jamesw
« Reply #4 on: July 02, 2021, 06:28:46 PM »
Those black plastic caps can be removed to facilitate further adjustment. I also have a 75F. If you remove the air screw, be careful not to lose the spring.
As for vacuuming synchronization, that other slotted brass screw is where you would screw in the adapter plugs that come with the synchronization tool. Once you have all four ready, you'd remove the gas tank, and have an auxiliary fuel tank so you could turn on the bike.  Then you'd slide back the black rubber dust caps and back off the 10mm nut, which then allows you to synch the carbs by adjusting the 17mm nut/spindle.
The other larger screw you'll see is attached to the stay plate (carb rack). This screw adjusts idle.
I just rebuilt 8 racks of round top carbs. If you have any other questions, just send me a PM.
The Hackaweek video series is good.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline Que75cb750
« Reply #5 on: July 02, 2021, 07:54:27 PM »
I imagine the stoppers on the air screws are factory set at xx amount and they give you a certain amount of adjustment?? What would this be factory set at? The Hackaweek videos are great, the syncing video was very informative but he didn’t get I to the air screw adjustment
« Reply #6 on: July 02, 2021, 09:34:19 PM »
Keihin carbs for CB750 K6 have those. I do not know when introduced. The air screw has splines for it. Earlier not.
Pull off if needed. Air screw setting 1 turn out +/- 1/8
« Last Edit: July 02, 2021, 09:36:16 PM by PeWe »
Offline Que75cb750
« Reply #7 on: July 03, 2021, 04:58:51 AM »
Awesome info Thanks, I guess my biggest issue was the stopper on the air screw, I didn’t realize they are removable and was wondering how they would come out. Have any of you had success with pod filters? Would lifting the needle a notch or 2 be enough or would the jets need to be bigger? I have heard that these carbs just won’t work properly with pods but I don’t know why they couldn’t.
« Reply #8 on: July 03, 2021, 06:19:01 AM »
 What size are the main jets in there now ? Stock would have been #105 for a 1975.
« Reply #9 on: July 03, 2021, 09:17:15 AM »
Save those nylon caps. I think not available anymore. If they are,  not cheap.
Offline Doobie
« Reply #10 on: July 03, 2021, 10:36:58 AM »
http://forums.sohc4.net/index.php/topic,182280.0.html
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
