Author Topic: 77 CB750 - resurrection  (Read 2735 times)
Re: 77 CB750 - resurrection
« Reply #25 on: November 15, 2021, 01:23:51 PM »
Any towers will fit and any cam will fit any towers, bearing caps have stamped letters for assembly as every one is differemt
Offline xhevi
« Reply #26 on: November 15, 2021, 01:45:13 PM »
thanks
how are the caps different? they dont interchange?
Offline newday777
« Reply #27 on: November 15, 2021, 04:26:34 PM »
thanks
Like crank bearing caps the cam caps are line bored as a set.
Stu
My current rides
Prior bikes....
Offline xhevi
« Reply #28 on: November 16, 2021, 07:18:51 AM »
Got it. Thanks
I saw the makings on the caps matching the markings on the holders.
That's something to look for when buying on eBay.
Offline xhevi
« Reply #29 on: December 03, 2021, 11:06:02 AM »
hi all.
I bought a used camshaft with both holders on ebay that are in great shape and usable.
The engine is now fully disassembled, both top and bottom ends.
Top end:
Exhaust valve guides need replacement.
Valves and valve springs are within spec.
Cylinder bores are to spec and no rust or pitting.
Have yet to measure the ring end gaps. Haven't bothered as I am looking at new rings.
Pistons are within spec. However there are small indentations, looks like the exhaust valves have been hitting the pistons.
Cam chain tensioner rubber bits (rollers and guide) have seen better days. Still look usable but I will replace with new.
Cam chain is DID 219T and judging by the amount of adjustment left on the cam chain tensioner it is likely OK to reuse.
Bottom end.
There are many signs that the cases were split once before.
Had a hard time removing the bearing holder and striped the 4 screws. Dremel and impact driver to the rescue.
All gears look great.
Have yet to measure clearances on the connecting rods bearings and crankshaft bearings. There is no up and down play on the connecting rods, only some side play.
There is some visible wear on the cases where the transmission and sprocket bearings sit.
All of the ball bearings are NTN with the exception of main-shaft bearing on the left side that is KOYO.
There is no play at all and no noise on the bearings when spun by hand.  When I place any of the shafts on the cases and spin by hand then I can hear the usual ball bearing noise.
Primary chain is marked RK. I measured 67.5mm from case to tensioner, That is slightly above the mid range of the Honda specs 64mm-70mm.
Primary chain tensioner rubber is still soft yet the edge of the rubber have some wear. Planning to replace it.
advice needed.
Top end:
1) Recommendations of a reputable shop to replace all valve guides, without having to throw away usable parts for new sets of valves and springs.
2) Recommended piston rings (standard). Prices vary from 40$ per one piston to a whole lot less for all 4.
3) Is valve hitting pistons due to excessive wear on the exhaust valve guides? Once the head it rebuilt I will check the piston/valve clearances using molding clay. If still an issue, then a thicker head gasket from CycleX is the solution?
4) Any better chains then DID 219T cam chain (stock?) and reasonably priced?
Bottom End.
5) How do you inspect transmission roller bearings? I know the advice is to replace with new. But looks like that someone before me already went through the trouble and expense, unless NTN with an one random Koyo were stock factory bearings.
6) Keep or replace the RK primary chain at half its lifespan?
Attached are a couple of photos to show the wear marks on the case where the bearings sit. Should there be wear marks in these locations? Are the outer races of bearing meant to spin? Similar wear is noted on the outer race of the bearings.
Thank you all.
« Last Edit: December 03, 2021, 11:15:01 AM by xhevi »
« Reply #30 on: December 03, 2021, 11:41:30 AM »
Check the ring gaps before ordering new, if in spec better toreuse than replace, only use genuine tensioners rubber on pattern is crap, for the cost ofreplace the camchain
Offline xhevi
« Reply #31 on: December 03, 2021, 12:03:41 PM »
Thanks bryanj.
Will check the end gaps. Prior to teardown I did a leak down test and numbers were very promising on 1 and 4 cylinders. No leak through the rings. #2 and #3 had no compression and both leaking from exhaust valves
Is there markings on the rings to determine if they are OEM or aftermarket?
I lost you regarding the tensioner and chain.
« Reply #32 on: December 03, 2021, 12:48:55 PM »
No markings for genuine,
Pattern tensioner rubber the rubber is a bad material so only use genuine.
The cam chain is relatively cheap so fit new
Offline xhevi
« Reply #33 on: March 15, 2022, 06:46:04 PM »
Can I save this tank?
All the little sparkly dots are pin holes on the right side. I am shining a light inside the tank.
I have the por15 tank sealer kit and so far have removed all loose rust and cleaned the inside with the por15 cleaner/degreaser. Next step was to apply the por15 metal prep then sealer.
I intend to leave the tank bare metal. I have yet to look into what and if clear top coat or other product to use to prevent rust.
Do you guys think the sealer can seal these holes?
Any other products to use maybe from the outside? Like a rolled or brush paint?
I was going to paint the seam black to have a visual break between the engine and bare tank. I can also cover the pin holes from the outside.
Thanks.
« Last Edit: March 15, 2022, 07:07:04 PM by xhevi »
Offline xhevi
« Reply #34 on: March 15, 2022, 07:20:33 PM »
Time to post some before and after photos.
Engine buttoned up with new primary chain and tensioner, new timing chain and tensioner, and all new seals.
Cylinder and pistons were in spec so I honed the cylinders and installed new rings.
Replaced head with another 392 with valve guides within spec. Lapped valves, new seals etc...
Used a gasket kit from CycleX with MLS head gasket.
Currently the carbs are apart, soda blasted and ultrasonic changed. I am waiting for felt rings to reassemble.
Offline BenelliSEI
  • 1969 cb750
« Reply #35 on: March 16, 2022, 01:29:15 PM »
I used CASWELL tank sealer on my K7, several years ago. It had the same holes as yours. When I finished I sat it so “extra” sealer ran down that seam. Still holding......
Offline xhevi
« Reply #36 on: March 16, 2022, 01:44:17 PM »
Thanks
Was thinking the same. Once most of the sealer is drained to lean the tank to it's right side and let the sealer set.
Good to know it works
Offline BenelliSEI
  • 1969 cb750
« Reply #37 on: March 16, 2022, 03:00:37 PM »
Good luck. CASWELL has never disappointed me. I have a local distributor not far away. Follow th directions to the letter. In the past, the smallest kit was easily enough to do two tanks.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #38 on: March 16, 2022, 03:05:33 PM »
Sorry to be so late
That photo of the cam in the head looks pretty rough, how did you clean that up?
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline ozpacman
« Reply #39 on: March 17, 2022, 04:19:53 PM »
Sorry to be so late
Offline xhevi
« Reply #40 on: March 17, 2022, 05:13:06 PM »
Sorry  haven't checked this
locally I found a usable head with camshaft, camshaft holders and everything else from an engine with half the miles.
« Reply #41 on: March 17, 2022, 06:45:22 PM »
Today I started to check the ignition bits.
The advance unit is frozen solid and there is rust pitting on the cam. It's a 300 advance unit.
Has anyone has used the 4into1 replica? I don't mind trying to save mine but a new one might be in order.
Thanks
Hmm...seems like you need my book to answer all those questions above?
The 4into1 advancer replica works, but use the springs from your old one. Their springs are wrong, and I have seen 3 different spring sets on the 3 I have bought. They are not correct, not one of those 3! The mechanical parts of it are otherwise fine.
« Last Edit: March 17, 2022, 06:47:44 PM by HondaMan »
Offline xhevi
« Reply #42 on: March 17, 2022, 06:52:54 PM »
Thanks HondaMan.
I managed to free up and clean the old one.
 But it's the springs that I think likely need to be replaced. So thin a wire must have section loss and strength from rust.
Any good source for advance springs?
« Reply #43 on: March 17, 2022, 07:07:35 PM »
hi all.
Top end:
INTAKE AND Exhaust valve guides need replacement.
I suggest using APE guides. You will need to have a machine shop install them and bore to proper clearances, which are TIGHT in this engine, and must be, or else it WILL burn oil afterward. Intake valve stems' clearance 0.0008"-0.0012", exhaust 0.0010-0.0018 (both are considered 'worn out' at 0.0024"). Then new valve seats must be cut to match the angle of the new guides. Yours might need exhaust valves: during valve refacing this will become apparent. New valves need not be refaced.
If you do not elect to rebore with new pistons, I suggest getting Honda's own rings. The oil rings are thinner than most of them found today, and the standard rings sets will not fit the grooves - too thick/tall.
Chances are the exhaust valves are then bent.
Bottom end.
Bearing clearance (Plastigage) should be less than 0.0024", or else the oil pressure will be very low when the engine is at temperature.
Spec clearance is 0.0008"-0.0012" new.
advice needed.
Top end:
I NEVER recommend thicker head gaskets for these engines, period. Thicker head gaskets WILL cause major oil leakage problems, specifically at the 2 rear oil passages where the head and cylinder meet. In addition, to use any standard head gasket made today, you must either mill the deck of the clinders by 0.010" to use the standard 2.4mm thick O-rings there, or else get a pair of 2.6mm thick ones from me (for a donation of any amount to SOHC4.com) or - both - which is how I rebuild these engines.
There is no normal situation in this engine where the exhaust valves can even hit the pistons, unless they were rust-seized from sitting a long time, and then the engine was started up. This scenario is, sadly, common with the F2/3 and K7/8 bikes because of the cast-iron valve guides: they wear quickly and rust easily when the oil is old and wet and the bike is parked a long time.
Bottom End.
Honda's 'distance' spec for primary chain wear on the K7/8 and F0/3 engines was...umm...optimistic. They were in midrange (i.e., about where yours are now) when the engines were first assembled. The gearing is such that they will typically last 80k miles or more if they do not have rust in them.
Thank you all.
« Reply #44 on: March 17, 2022, 07:11:36 PM »
Thanks HondaMan.
The springs are usually quite robust, but became somewhat sacked from engine heat long ago. This let them advance much too soon. The result is some mild spitback at teh carbsbetween about 1800 RPM (when they hit full advance too soon) and 2500 RPM (when they are supposed to). I often cut off 1 turn from each spring and reinstall them so the advancers hit full a little closer to 3000 RPM, which matches up better with the burn rate of our ethanol-laden, slower-burning fuels today. In the end, I also recommend no more than midgrade fuel in this engine, because of it slower-burning nature. Midgrade today burns slower than premium from the 1970s era did! This is needed in modern cars to help sustain the catalytic convertors, so it is universal in the USA, and probably elsewhere.
Offline xhevi
« Reply #45 on: March 17, 2022, 07:15:09 PM »
Thank you HondaMan!!!!
Much appreciated that you took your time to go over the entire thread and advise.
I think (hope) to have engine buttoned up. Still ways to go before I hit that start button.
Might asks someone else to first start it in case it blows up 😆😆😆
