Author Topic: wire terminal contact for starter switch  (Read 794 times)
Offline mrenfro
« on: October 24, 2021, 03:02:30 PM »
I may be trying to go too cheap here, but I have a 73 CB350F with a messed up starter switch.  Specifically, the contact at the end of the wire that is grounded when the button is pressed is missing.  I've attached a pic of this contact.
Does anyone know of a clever workaround for when this piece is missing that still makes use of the original button/spring/contact plate?
Offline Flyin900
Re: wire terminal contact for starter switch
« Reply #1 on: October 24, 2021, 05:08:21 PM »
You can buy a replacement switch entirely from 4 into 1 out of San Fran for about $50.00 that are decent quality for a rider bike and your all set with new contacts etc.
If you wish to go cheaper than that well I am sure there are other options too.
https://4into1.com/reproduction-throttle-switch-assembly-35300-323-671-honda-cb500-cb750/
It notes this can be used on a CB350F so measure your wire length if you go this route.
« Last Edit: October 24, 2021, 05:13:56 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline Kenzo1979
« Reply #2 on: October 24, 2021, 05:11:18 PM »
These look and work great.  I also added a relay.  You want the normally OPEN version though (pic says opposite).
« Last Edit: October 24, 2021, 05:17:48 PM by Kenzo1979 »
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline Kenzo1979
« Reply #3 on: October 25, 2021, 06:06:32 AM »
If you just need the piece in the pic, I’ll look and see if I have one.  But you could probably make your own from a copper rivet and a piece of masonite or fiberglass or some type of small project insulation board (like type g11 - circuit board blanks).  If you have the half moon insulation board piece and just need the contact, you can get a copper rivet and then just solder to the back of it.  Or just replace it with a modern momentary switch.
--Kenzo
« Reply #4 on: October 25, 2021, 11:05:13 AM »
Steal the horn button contact.
