It is an interference fit, meaning you'll need to put it in a press or use a vice with a bushing (or similar).
But 2.3mm is A LOT of difference. Just to confirm, as bryanj previously asked, when the old bushing was pressed out, the outer sleeve came out with it, right?
The ideal way to enlarge the hole to fit the bushing is with an adjustable hand reamer. There is another way, but you wouldn't like it.
