Author Topic: Stainless steel bolts  (Read 1229 times)
Offline amitr0
« on: December 17, 2021, 05:50:57 PM »
I want to upgrade all the engine cover case hardware with stainless steel alan bolts.
What grade of steel should i look for?
Also, where do I source such bolts, the threading is mostly 1 mm but the sizes vary, is there a kit available for this?
This is for a '76 cb550k.
Offline BenelliSEI
  • 1969 cb750
Re: Stainless steel bolts
« Reply #1 on: December 17, 2021, 06:33:46 PM »
Check EBay.com. Kits usually available there.
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
« Reply #2 on: December 17, 2021, 06:34:41 PM »
Take caution when using stainless steel fasteners with aluminum parts because of the galling that can occur between the soft/hard metals. A common practice that I’ve learned is to Helicoil the aluminum threaded holes and use zinc-plated steel screws.
Any engineers out there to confirm?
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: December 17, 2021, 06:44:49 PM »
I just coat them in antisieze. The real issue is they are very easy to over torque. I always use a 1/4 drive ratchet and snug them up very gently. They don’t need much at all to stay tight (how much torque can you really generate with a JIS screwdriver? Probably why Honda used them in the first place).
Offline CycleRanger
  • No comment about being an
« Reply #4 on: December 17, 2021, 07:52:58 PM »
Yes, I used stainless bolts on my XS650 with a little anti-seize.
Offline amitr0
« Reply #5 on: December 17, 2021, 07:58:19 PM »
The original screws are also not aluminum though? They are iron which is stronger than aluminum.
I  omay replacing with stainless steel JIS screws as well,, overtorqueing with JIS would be hard as you rightly mentioned.
Offline newday777
« Reply #6 on: December 17, 2021, 11:48:26 PM »
Stu
My current rides
Prior bikes....
Offline markmyodb
  • Honda owner since 1969. 19 Honda motorcyles, cars, and lawn mowers through the years!
  • Always looking for SOHC people to ride with in NC
« Reply #7 on: December 18, 2021, 04:13:43 AM »
I was taught, during my engineering career, that stainless steel bolts are best for aluminum, always use some lubricant, and always torque to specification. Always make sure they will engage at least 2X the diameter of the screw, 12mm for a 6mm screw. I have found most of the tapped holes in the 750 and 550 cases will handle about 3X the diameter I am sensitive to the feel as I thread them.  If there is an increase torque required to thread the screw, I stop  and cut them down a few millimeters.  I make sure to chamfer the cut end to remove any r
Zinc plated screws corrode in the case as most of us can attest too when we remove those with an impact driver and find the white powder in the threads.  Takes a long time to corrode, but it is not good for easy removal after decades.
I was never taught to use a specific grade SS. Prefer to buy 316 grade stainless as they are readily available from McMaster Carr.
I put them in my 750K6 in 2008, no issue 13 years later when disassembled.
I tell my wife the motorcycles are an investment...
CB550K1: 1975
CB750K6: 1976
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #8 on: December 18, 2021, 01:53:52 PM »
Clean the holes with a good tap
Use a torque wrench to avoid over torque
Use a good high temp antiseize on all of them unless locktite is called for
The kits are usually good but check depth just in case, it’s easy to crack your casting
Be sure there is no liquid in the blind holes, you will surely break the casting if it’s got liquid in it
Use flat washers under the heads because most socket heads are smaller
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #9 on: December 18, 2021, 02:37:27 PM »
as above poke and probe then blow clear the holes,theres often blobs of silicone and other debris stopping your screws from going as deep as they should,never torque a 6mm bolt just snug them down.
Offline flybackwards
« Reply #10 on: December 18, 2021, 03:42:19 PM »
Offline Alan F.
« Reply #11 on: December 18, 2021, 05:13:16 PM »
Nobody remembers the guy who practically invented these kits?
http://www.metrocast.net/~spillane/index_002.htm
« Reply #12 on: December 18, 2021, 06:18:49 PM »
Definitely use washers every where you can and liberaluse of a good anti seize paste.
Offline Kevin D
  • SE Michigan
« Reply #13 on: December 19, 2021, 05:47:06 AM »
Gardner Westcott is not too far from here. I have never done any business there but it looks like they offer many varieties of Allen bolt kits.
71 CB750 K1
106,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #14 on: December 19, 2021, 07:24:51 AM »
Some sellers have polished parts where there is no texture on the bolt head's circumference...if you prefer that look.
