Author Topic: CB750 F2 1977 Master Cylinder Rebuild  (Read 1335 times)
Offline zalion0
« on: January 12, 2022, 02:46:21 AM »
Hi all, I was wondering if you could help me. The next stage of my project is to rebuild the stock master cylinder. I've cleaned and cleared out the existing one and the rebuild kit has arrived. Does anybody have an exact guide for type of master cylinder, all the ones I've seen so far are for a different (e.g brake fluid bowl is a plastic part vs all-in-one metal).
I've checked the shop and Clymer manual but these appear to be slightly different to what I have. My understand of the order is
Rubber Boot - Circlip - Washer - Piston (with secondary cap)- Spring - Check valve.
I've noticed on some other threads and videos, some kits are supplied with a pink ish grease. My kit was not. What is this grease and where is it applied?
Many thanks :)
Re: CB750 F2 1977 Master Cylinder Rebuild
« Reply #1 on: January 12, 2022, 09:39:45 AM »
I sold my 750 F model a couple years ago but my MC did not look like yours, has it been modified?
Here's the fiche...
https://www.partzilla.com/catalog/honda/motorcycle/1977/cb750f-a-750-super-sport/front-master-cylinder
« Reply #2 on: January 12, 2022, 09:53:34 AM »
 I'm not an expert but that looks like a gl1000 M/C. It could take the same kit, but I'd check it out first.
Offline zalion0
« Reply #3 on: January 13, 2022, 12:38:18 AM »
It hasn't been modified and as far as I can tell is the stock master cylinder. I'll take some more photos shortly.
Offline newday777
« Reply #4 on: January 13, 2022, 02:48:16 AM »
Sorry but that master cylinder is not the stock master from your 1977 F2. (I included your picture)
The stock front master cylinder reservoir was cast as 1 piece on the master. See 2nd picture...
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #5 on: January 13, 2022, 02:57:51 AM »
Like Don said your master cylinder is more likely from a GL1000
Stu
My current rides
Prior bikes....
Offline zalion0
« Reply #6 on: January 14, 2022, 12:31:23 AM »
Thanks all, I was also looking at other photos as well. This is also a F2, same colour etc and year and appears to have the same master cylinder! The mystery continues haha!
Looks like that GL1000 Master Cylinder also takes the same rebuild kit I have here, so we maybe in luck.
Thanks for all your help so far everyone  :D
« Last Edit: January 14, 2022, 12:35:33 AM by zalion0 »
Offline Doobie
« Reply #7 on: January 14, 2022, 03:59:09 AM »
I rebuilt a CB900F MC the other day and I figured it out by looking at a parts diagram, which shows the order in which the parts go together.
I can't think where you would need grease when rebuilding an MC but I've bought brake caliper kits that included red rubber grease for the gaskets to make it easier to insert the piston into the barrel. You could use any grease really.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline newday777
« Reply #8 on: January 14, 2022, 07:54:15 AM »
No grease is needed. Just dip the rubber cup in a cap of fresh Dot4 to help it slide in...... It's worked for years doing that.
Stu
My current rides
Prior bikes....
Offline zalion0
« Reply #9 on: January 14, 2022, 07:58:11 AM »
Awesome, I’ll do that. Will attempt the rebuild this weekend!
Offline BenelliSEI
  • 1969 cb750
« Reply #10 on: January 16, 2022, 05:42:00 PM »
How’s your bike running? Get the tabs sync’d and sorted?
« Reply #11 on: January 16, 2022, 05:46:14 PM »
 I wonder if this was a running parts change that sometimes occurred during a model run?
Offline zalion0
« Reply #12 on: January 17, 2022, 01:02:52 AM »
Slow progress, but getting there! The carbs still aren't idling properly (despite me cleaning, cleaning again, ultrasonic cleaning and re-confirming all passages and jets) so I do need to sync them I believe at some point. I'm also going to bite the bullet and replace the carb to engine rubbers as these are 40yrs old plus! Its a bit cold in the UK at the moment, so working in the shed without a heater is a bit of a mission! I'm doing as much extra as I can indoors (so brakes, dials etc) to make the most of it. Next big tasks I want to complete is getting the bike hoisted up, so I can remove front forks and replace seals, change the tyres, clean up the wheels etc. Then I'll be started on the back (so same again, wheels, brakes, forks etc) and finally clean out the inside of the tank.
Its a slow progress and every job seems to involve buying a new tool (snap ring pliers, grease gun etc) but loving it all so far!
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #13 on: January 17, 2022, 06:10:22 AM »
Sure is 1 pretty bike!
« Reply #14 on: January 17, 2022, 07:03:32 AM »
Are you on the UK forum? SOHC.CO.UK
Offline Translations
« Reply #15 on: January 17, 2022, 01:25:05 PM »
Any idea of this would be a worthwhile upgrade for a F2? Sure would be nice to see the level of your brake fluid.
78' CB750F Super Sport
Offline zalion0
« Reply #16 on: January 27, 2022, 05:24:45 AM »
Figured, i'd share some more progress! Master cylinder rebuild kit should be here tomorrow, the correct one this time! Ready to sort at the weekend. I've also used the grease gun method as well and have managed to extract the pistons from the callipers. Still need to clean up the grease and so on. This is their current state from sitting for 38ish years!
« Reply #17 on: January 27, 2022, 08:39:21 PM »
You need new pistons
Offline zalion0
« Reply #18 on: January 27, 2022, 11:09:06 PM »
Agreed, they are badly pitted. I’ll be ordering seals as well.
« Reply #19 on: January 28, 2022, 03:51:04 AM »
Use a dental pick or similar to clean all the crud out of the seal grooves especialy the corners, a dremel dont wor it just polishes the crud
Offline zalion0
« Reply #20 on: January 28, 2022, 04:25:08 AM »
Awesome thanks Bryant, I guess I can be quite firm with the dental pick and not worry about gauging the calliper?
« Reply #21 on: January 28, 2022, 04:28:55 AM »
You can feel the crusty crud in there, dont remove lumps of alloy though
Offline zalion0
« Reply #22 on: January 28, 2022, 04:31:06 AM »
Perfect, appreciate your help :)
Offline newday777
« Reply #23 on: January 28, 2022, 05:02:10 AM »
Firm yes. Keep the dental pic in the seal groove.
But....Do not scratch the bore!
Stu
My current rides
Prior bikes....
