Author Topic: How to rivet the VIN tag to the frame  (Read 11711 times)
Offline rhinoracer
« on: March 02, 2007, 11:58:28 AM »
I removed the VIN tag to powdercoat the frame, it was riveted plus it had some kind of double sided clear tape.
I have the glue-tape part worked out, I even got some #4-40 screws and tap to replace the rivets.
My plan is to use Scotch double sided tape (the thinnest film available) and fasten with the slotted head screws, then grind the slot away and bang on them to make them look more like rivets.
Is there a better or proper way?
Baja native.
Offline MrFry
    • T-Fry.com <--Under Construction
Re: How to rivet the VIN tag to the frame
« Reply #1 on: March 02, 2007, 12:04:29 PM »
^^beat me too it
rivet guns aren't all that expensive...
Offline rhinoracer
« Reply #2 on: March 02, 2007, 12:20:34 PM »
The original rivets had tiny heads and were the solid type.
Just trying to keep the same appearance. I was tempted to use pop rivets but don't really like the bulky heads. However, if that's the way everybody does it maybe I'll give it a try.
Baja native.
Zane
« Reply #3 on: March 02, 2007, 12:32:39 PM »
I'd call a good road bicycle shop and explain what you want.  Most of them are able to do a neat job of riveting metal steering stem emblems, I think.  (My local shop did, anyway.)
Offline Geeto67
  • A grumpy
« Reply #4 on: March 02, 2007, 12:39:14 PM »
If I am not mistaken there was some place selling the proper rivets, I forget who though. Maybe DSS?
Maintenance Matters Most
Offline heffay
« Reply #5 on: March 02, 2007, 12:39:40 PM »
my rivet gun has 4 different size rivet holders that are interchangeable.  from very small rivet to pretty large ones.
i think the whole setup including an assortment of rivets was in the 20-25 dollar neighborhood.  honestly, i don't remember where i got it but, i've seen the same one in several different stores.  it has paid for itself in the 5 years that i've had it.
here is a picture of it...
« Reply #6 on: March 02, 2007, 12:40:57 PM »
For gluing the plate, some good old clear silicone adhasive is all you will need. As for rivieting the plate back on you seem to have that figured out. If you glue it on with silicone, you could glue something that looks like the rivet head over the holes.
Offline cb650
« Reply #7 on: March 02, 2007, 03:26:40 PM »
I just used regular rivets but they do make a hammer in that would look more original.
Just how many times has anybody had the cops check your vin anyway?
                        Terry
Offline puppytrax
« Reply #8 on: March 02, 2007, 03:40:25 PM »
On a related note, I bunged up my VIN plate getting it off. Is there anybody selling blank VIN plates for these old bikes?? I know, that sounds pretty stupid, but you can get new VIN plates (blank) for old Triumph/MG/Austin-Healey autos from The Roadster Factory, so maybe someone knows where to get new blank VIN plates for Hondas...   ::)
Otherwise, I'll just do a photoshop black & white paper plate and epoxy it on and then clearcoat it...Best I can come up with...   :P
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline heffay
« Reply #9 on: March 02, 2007, 03:44:30 PM »
puppy... is it a resto that you can't do w/ out correctness?  because, a piece of laminated paper is not correct.
otherwise, skip it... that would be fraudulent and it would better for you to keep the bunged up one.  things get scratched its understandable.
Offline puppytrax
« Reply #10 on: March 02, 2007, 03:58:44 PM »
It doesn't have to be a 100-point restoration; but the mounting holes are pretty ripped out...I could only fasten it by drilling new holes somewhere else...and riveting it on again...but it would look like exactly what it is: a ripped out & refastened VIN plate...   ::)
Offline Steve F
« Reply #11 on: March 02, 2007, 04:26:42 PM »
What you're looking for isn't really a rivet at all, but what's known by some as a drive screw.  Rivets are usually peened over on both ends.  A drive screw is shaped like a rivet, but has a spiral knurl on the shank, and is just pounded into a hole with a concave punch.
Check out this link where you can buy them.
http://www.mcmaster.com/param/asp/psearch.asp?FAM=nails&FT_4565=201257&FT_785=201219&FT_518=52165&FT_4569=201280&session=nails,4565=201257,785=201219,518=52165;4569=201280
Offline heffay
« Reply #12 on: March 02, 2007, 04:27:24 PM »
right... but, a privately reproduced one will only look fraudulent.  at least, a paper and non-authentic looking reproduction.
« Last Edit: March 02, 2007, 04:32:13 PM by heffay »
okie
« Reply #13 on: March 02, 2007, 04:29:43 PM »
A good trophy shop can make any tag you can imagine.  On street rods, I used brass drive rivets that had a shallow angled spiral on the shaft that allowed a good tight fit in a properly sized drilled hole.  You just placed the rivet on the hole and whammed it with a hammer.  It looks exactly like a factory job.   You can get the rivets here:
http://www.snydersantiqueauto.com/ModelAParts/DataPlates/3327?partnumid=
« Last Edit: March 02, 2007, 04:36:47 PM by okie »
« Reply #14 on: March 02, 2007, 08:04:03 PM »
I believe these fellows can help with a new Vin Plate.
Offline spitfire
« Reply #15 on: March 03, 2007, 10:25:45 AM »
Put mine back on with normal (small) rivets and "no nails" adhesive, looks OK to me !
Cheers
Den
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
Offline SWEETPEAUK
« Reply #16 on: March 03, 2007, 12:50:17 PM »
The Part you need is.
screw Rivit 1.5 x 5
Honda Part No 90841-000-000
They are also used by clock makers, so no an hard  item to locate.
I believe you hammer them in lightly and they grip by side expansion.
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« Reply #17 on: March 03, 2007, 06:06:55 PM »
Place carefully and lightly in hole and pound in place with ten pound
sledge.  ;D
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline crazypj
  • I'm brill, me
« Reply #18 on: March 03, 2007, 09:17:51 PM »
I made some from 0.125" stainless steel welding rod. I thought originals were 1.5mm but didn't remember length required
Made with slight taper on shaft so they jammed in position
PJ
Offline puppytrax
« Reply #19 on: March 04, 2007, 05:49:17 AM »
I plan on using brass brads, available from any hardware store, and use a long drift to push the ends over, inside the headstock...
As to the VIN plate, I am going to glue my clear-coated digital photo of the VIN plate to a piece of aluminum flashing (also at hardware store) and rivet that on...It's the best I can come up with...As for official inspection, as long as the VIN on my plate matches the VIN stamped into the other side of the headstock, I don't see a problem...
Offline heffay
« Reply #20 on: March 09, 2007, 02:36:04 PM »
took a ride over to harbor freight today.
checked out the rivet tool selection.  the one i pictured earlier was 5.99 and they ranged up to about 15 or 20 bucks.
there was an assortment box of probably 200 pieces and it was only about 3 bucks.
i've got lotsa goodies  ;D
Offline old750
  • Hippy ass bike.
« Reply #21 on: March 09, 2007, 04:51:14 PM »
I also need a VIN plate as my bike didn't come with one. It had a number directly etched on the frame. Is this also a VIN? My papers match the number on the frame so I guess it don't matter if I have a plate or not.
