Author Topic: 1977 Kawasaki KZ1000 LTD  (Read 6429 times)
Offline BenelliSEI
  • 1969 cb750
Re: 1977 Kawasaki KZ1000 LTD
« Reply #25 on: August 15, 2022, 05:25:31 AM »
You won’t be Disappointed!
Offline Kelly E
  • Geriatric Hooligan
« Reply #26 on: August 15, 2022, 10:34:26 AM »
I think I will clean up the Kerker and sell it. The Kerker has a dent just behind the collector, a couple of dings and a flat spot on the bottom of one of the pipes. The chrome has seen better days but the system is still solid. We're going to put a Delkevik exhaust on it.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Kelly E
« Reply #27 on: August 23, 2022, 09:58:30 AM »
I've been busy cleaning up the bike and especially the motor. It had four decades of oil and road grit encrusted on it.
1983 Honda CB 1100F
Offline Kelly E
« Reply #28 on: August 28, 2022, 01:18:28 PM »
Yesterday we got the front brake caliper pistons out. They both have small damage to them so they have to be replaced along with the rear brake caliper piston. I need to mount the new handlebars so we can measure for new shorter upper front brake line and get the lines ordered. Need to order steering head bearings too.
We also pulled out the original wheel bearings and replaced them. The wheels got dropped off for the new tires yesterday afternoon.
1983 Honda CB 1100F
Offline Kelly E
« Reply #29 on: September 04, 2022, 09:34:47 AM »
Yesterday we decided to pull the motor to blast and paint the frame. There's just too many scratches and rusty spots to look past. We're almost ready, just need to pull the coils and a couple of little things.
1983 Honda CB 1100F
Offline Mark1976
« Reply #30 on: September 04, 2022, 05:04:03 PM »
Well,  when your that far along you may as well go a little further. It'll look as good as it goes. Anything worth doing is worth doing right. Ya also get piece of mind that the frames intact as well.
Start with the end in mind...
Offline Kelly E
« Reply #31 on: September 13, 2022, 04:03:45 PM »
The motor is out and on the stand. I just finished the third major cleaning on the motor and now it looks like it is made from aluminum not 45yo baked on grease and oil. It should take at least 3 or 4 cleanings to get it good enough. Waiting for blast media to get the frame done and start sanding all the rest of the of the parts that we did in the blast cabinet.
« Last Edit: September 13, 2022, 04:06:07 PM by Kelly E »
1983 Honda CB 1100F
Offline BenelliSEI
  • 1969 cb750
« Reply #32 on: September 13, 2022, 05:51:54 PM »
Will be worth the extra effort!
Offline Kelly E
« Reply #33 on: September 18, 2022, 08:26:08 AM »
I finally finished sandblasting the frame and some parts. We hope to get the frame sanded and painted before the weather turns.
1983 Honda CB 1100F
Offline grcamna2
« Reply #34 on: September 18, 2022, 09:10:23 AM »
I like the design of that frame  8)
Offline Kelly E
« Reply #35 on: September 18, 2022, 11:44:08 AM »
It's a good design but they sell frame bracing kits for them. The front half of the frame is very similar to the front half of my 94' Kawasaki ZG 1000 Concours. It thinks it's a Ninja on curvy roads. 8)
1983 Honda CB 1100F
Offline BenelliSEI
  • 1969 cb750
« Reply #36 on: September 19, 2022, 11:13:02 AM »
Looks like a full restoration to me! Nice job.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #37 on: September 19, 2022, 02:44:00 PM »
That frame looks great
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Kelly E
« Reply #38 on: September 19, 2022, 04:55:33 PM »
Thanks guys, all of the cleaning up is done except for 1 or 2 more sessions of motor cleaning.
1983 Honda CB 1100F
Offline Kelly E
« Reply #39 on: October 08, 2022, 06:22:21 PM »
Last weekend we got the frame sanded cleaned and painted. Over the week I got some of the small parts painted. Today I sandblasted a 1969 Honda CB 750 frame for a friend of Paul's.
« Last Edit: October 08, 2022, 06:28:16 PM by Kelly E »
1983 Honda CB 1100F
Offline Kelly E
« Reply #40 on: November 04, 2022, 07:47:20 PM »
We finally tracked down a new centerstand. This model came with the mounts on the frame for it but no centerstand. Every place we checked was out of stock and then last week I found a place that said they had one. It is a repop so it's not perfect. The bores on the stand are too big so we had to shim them with .012" aluminum strips so it doesn't rattle while riding. Tomorrow we'll put the frame on the motor and set it up on the lift table for assembly.
1983 Honda CB 1100F
« Reply #41 on: November 04, 2022, 08:52:07 PM »
Glad you found one. Look forward to seeing it out on the road ripping up the countryside...
Offline Mark1976
« Reply #42 on: November 05, 2022, 07:50:34 AM »
   Back in the day, the first thing ya did after installing a decent header was ditch the centerstand. Now its the first thing I look for when buying an old bike and trying to find a replacement is next to impossible. There's gotta be a centerstand graveyard out there somewhere.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #43 on: November 05, 2022, 02:59:52 PM »
Nice project!
1973 CB 750 K3
Offline Kelly E
« Reply #44 on: November 05, 2022, 06:59:41 PM »
Today we put the frame on the motor and set it up on the centerstand on the lift table. There was a huge windstorm and the power was out so we had to open up all of the big roll-up doors so we could see.
« Last Edit: November 05, 2022, 07:03:20 PM by Kelly E »
1983 Honda CB 1100F
« Reply #45 on: November 05, 2022, 07:01:42 PM »
Nice
Offline grcamna2
« Reply #46 on: November 05, 2022, 07:17:37 PM »
Kelly,did you restore the swingarm ?
Offline Kelly E
« Reply #47 on: November 05, 2022, 07:54:33 PM »
I cleaned it out really well. It has dual needle bearings on each side. Everything looks good so I repacked the bearings and it's going back on with a Craigslist rebuild. 8)
« Last Edit: November 05, 2022, 07:57:20 PM by Kelly E »
1983 Honda CB 1100F
Offline grcamna2
« Reply #48 on: November 05, 2022, 08:29:35 PM »
Dual needle bearings stock? Nice !
What's a "Craigslist rebuild" ?
« Reply #49 on: November 05, 2022, 08:47:26 PM »
That's pretty generous to call a clean and repack of bearings a rebuild, most don't come close to that in their rebuilds...
More like wipe off any visible old grease and swipe a thin layer of new grease on that area to give it the appearance of being redone...
Typical Craig's list rebuild imho
« Last Edit: November 05, 2022, 08:50:04 PM by RAFster122s »
