Author Topic: m.Unit Wiring Diagram  (Read 6512 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
Re: m.Unit Wiring Diagram
« Reply #25 on: March 04, 2023, 09:39:49 AM »
Ellz- from your “stator” the Blu/Red is OIL pressure and Grn/Red is NEU switch. Those are in your stock harness bundle but don’t actually come from the stator.
So as pictured? Blue/Red goes to the bright White wire on the far right? Then the old crusty Green (middle) and what I imagine used to be the color White (left) connect to Green and White respectively?
« Last Edit: March 04, 2023, 09:45:49 AM by Ellz10 »
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Offline Ellz10
  • ZZ
« Reply #26 on: March 04, 2023, 09:45:28 AM »
The REC gets YYY, WHT and GRN.
In these scenarios, solid GRN is a ground.
So here, YYY goes to YYY. Easy, makes sense. Then does that mean that Green goes to Green and then that would leave Red from the REC going to White? Is that correct?
« Last Edit: March 04, 2023, 10:01:47 AM by Ellz10 »
Offline Ellz10
  • ZZ
« Reply #27 on: March 04, 2023, 09:51:36 AM »
For the REG side of your device, BLK, WHT and GRN go to the Stator.
And then finally the REG. Green goes to ground as you mentioned in these scenarios. Now I've got Black and White - which one goes to Blue/Red and which one goes to Green/Red?
For some reason I had initially thought Black was going to AUX 2, probably because that's how I saw it on the diagram.
« Last Edit: March 04, 2023, 09:57:08 AM by Ellz10 »
Offline Ellz10
  • ZZ
« Reply #28 on: March 04, 2023, 02:12:37 PM »
Blu/Red and Grn/Red DO NOT connect to any part of your Reg/Rec.
Understood. So the green/red neutral switch and red/blue oil pressure wires get wired into the speedometer gauge?
All the different colored wires for the one thing is severely confusing.
Offline Ellz10
  • ZZ
« Reply #29 on: March 04, 2023, 03:07:27 PM »
Okay so instead of continuing to ask these questions without proactively looking into how things work, I decided to do what I should've done from the beginning. So I studied the wiring diagram from the book, read several threads and I finally have a bit more understanding.
So here it goes and please correct me if I'm wrong:
From the REC, there's 5 wires - 3 YELLOW, 1 RED, and 1 GREEN
The 3 YELLOW & 1 GREEN go to the STATOR.
The 1 RED goes to the STARTER SOLENOID.
From the REG there are 3 wires - 1 GREEN, 1 WHITE, & 1 BLACK
The 1 GREEN goes to Ground.
The 1 WHITE goes to STATOR.
The 1 BLACK goes to AUX 2.
The 1 bright WHITE wire circled in the photo gets sleeved to the BLUE/RED (OIL PRESSURE) wire which then goes to the main speedometer gauge along with the GREEN/RED (NEUTRAL) wire and they both will get Grounded there.
The only thing that's bothering me is that I feel like I'm missing the link/wiring from the STARTER MOTOR to the STARTER SOLENOID.
******Edit to this last part regarding the starter motor******  I'm still trying to get used to the fact that not all black wires mean ground. After watching a few videos, it's now my understanding that the black wire that comes out of the starter motor is indeed meant to connect to the starter solenoid. Is that accurate?
« Last Edit: March 04, 2023, 03:33:38 PM by Ellz10 »
Offline Ellz10
  • ZZ
« Reply #30 on: March 05, 2023, 02:40:41 PM »
Alrighty, I'm all done I believe.
This is what I came up with.
Offline Shtonecb500
    • Youtube profile
« Reply #31 on: March 06, 2023, 12:28:11 AM »
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline Snider1970
« Reply #32 on: October 19, 2023, 05:10:20 PM »
I have a 78 I'm wiring up but keeping the stock controls.  I want to keep a vintage patina look.  I noticed on the revival wiring diagram the black wire going from the rectifier to the m.unit Aux 2.  Is this for the lithium battery?  I am using the lead acid.and my rectifier has only one black wire coming from it.
Offline raidermoto
    • raidermoto.com
« Reply #33 on: November 13, 2023, 11:46:11 PM »
We've installed several m-units and from memory they're only an earth trip unit, which is great & simple but not functional with a 3 way switch like required for lights.  Having said that, I know they have released a new version so perhaps this has been rectified.
Cheers M
There's no such thing as dumb questions, only dumb mistakes.
