Author Topic: CB750K Cylinder Head Intake Manifold  (Read 3188 times)
Offline Wizard
« on: January 27, 2023, 07:31:56 PM »
Hi just thought I would share sourcing CB750K screwed intake flange adapter manifold.
In short, I removed adapter from head and damaged it and wasn't able to reuse I have a machining background with a bit of time was able to make a new one so I am sharing some notes.
« Last Edit: February 21, 2023, 08:06:21 PM by Wizard »
Offline newday777
Re: CB750K 3
« Reply #1 on: January 27, 2023, 07:57:27 PM »
Welcome aboard the forum Wizard
You didn't see a part number for them because they came only with the head.
Did you take one out of the head?
Stu
My current rides
Prior bikes....
Offline Wizard
Re: CB750K 3
« Reply #2 on: January 27, 2023, 08:02:31 PM »
I removed one to get the correct rubber insulators as my bike has a K3 Motor with PD41 keihin carbs.
Offline Wizard
Re: CB750K 3
« Reply #3 on: January 27, 2023, 08:09:00 PM »
Thanks for clearing up part number look like I will have to make one thread dia 33.5 guessing.
Offline CycleRanger
  • No comment about being an
Re: CB750K 3
« Reply #4 on: January 27, 2023, 08:42:24 PM »
Impressive that you got it out intact. More often than not they don't.
Offline Wizard
Re: CB750K 3
« Reply #5 on: January 27, 2023, 08:52:45 PM »
I used heat to remove came out ok thread is stripped on adapter but head looks ok photo attached was not mine just for reference.
Offline newday777
Re: CB750K 3
« Reply #6 on: January 28, 2023, 12:26:48 AM »
Hmmm. K3 didn't come with PD41 carbs.
Are you sure it is a K3?
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
Re: CB750K 3
« Reply #7 on: January 28, 2023, 05:32:39 AM »
Use the correct thread chaser file, repair that one, and put it bacK. Coat it in a good anti seize lubricant and work it in and out until it’s back where it belongs.
Offline Wizard
Re: CB750K 3
« Reply #8 on: January 28, 2023, 12:53:58 PM »
Thanks for advice will use a thread file and refit best advice to all only remove these if it's last call.
