Author Topic: Gas cap rubber seal installation question  (Read 1099 times)
Offline Scott S
« on: April 16, 2023, 02:23:08 PM »
 I replaced the crumbling gas cap seal on my CB500 tank with a fresh new one.
 There's a thick side and a thin side. Logic told me the thick side faced out to seal against the filler neck. But I CANNOT get the cap to latch that way.
 Do I have it backwards?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
Re: Gas cap rubber seal installation question
« Reply #1 on: April 16, 2023, 03:11:52 PM »
 Well, I don't think it's the seal. The new, genuine Honda locking gas cap won't catch even with the seal out.
'71 CB500 K0
'81 Yamaha XS650
Offline Kevin D
  • SE Michigan
« Reply #2 on: April 16, 2023, 03:55:36 PM »
Scott, a long time ago (15 yrs), I got a new shiny genuine gas cap and it didn’t fit my tank. Checking the part numbers, I found a later part number was substituted and the later part had a thicker gasket. I told the vendor about the swap and they weren’t listening/didn’t care, but I bought the early thinner gasket and fitted it to the new cap and all was well.
 It’s 15 years Scott, I don’t know if I can dig out the details, but I see you have 71 CB 500, mine is a 71 CB750, simlar parts?
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Scott S
« Reply #3 on: April 16, 2023, 04:02:03 PM »
 I got it. I removed the latch from the tank and installed it on the cap. That seemed to "reset" something. It's working now, but tight.
 By the way, I just discovered this today. That's a MUCH easier way to install the seal!
'71 CB500 K0
'81 Yamaha XS650
« Reply #4 on: April 21, 2023, 11:35:43 PM »
Cool tip Scott, thank you for sharing!
« Reply #5 on: April 22, 2023, 02:21:21 AM »
also under that cap once its apart there will by a ton of crud.
