Author Topic: Fuel Line Size  (Read 870 times)
Offline Vintageguy
Fuel Line Size
« on: May 30, 2023, 11:18:04 AM »
Anyone know offhand what size fuel line for 1978 750F? Think it is 1/4" but not sure. Thanks.
Offline Alan F.
Re: Fuel Line Size
« Reply #1 on: May 30, 2023, 11:46:04 AM »
Stock was 5.5mm (.216") it's available online but it's not particularly cheap.
Offline Vintageguy
Re: Fuel Line Size
« Reply #2 on: May 30, 2023, 01:15:05 PM »
Seems as though 6mm would work?
Re: Fuel Line Size
« Reply #3 on: May 30, 2023, 01:29:13 PM »
Not without leaks if 5.5mm is stock, 6mm is gonna leak
Offline grcamna2
Re: Fuel Line Size
« Reply #4 on: May 30, 2023, 01:47:11 PM »
The auto parts places sell 5.5mm vapor hose;I've used 3/16" hose which fits tight.
75' CB400F/'bunch o' parts'
Re: Fuel Line Size
« Reply #5 on: May 30, 2023, 05:12:22 PM »
Think that is what I use also on 750's etc.. Bought a whole big spool of it when a hardware store was closing. It has worked well for me. Little warm up on the end with a heat gun and a little grease on the mounting nipples and its easier to get on or off and no leaks or clamps.
Re: Fuel Line Size
« Reply #6 on: May 30, 2023, 08:54:00 PM »
Same spigot size as CB750 K0-K4 dual spigot petcocks?
I use 6mm hose by Gates, their Barricade. Work fine with mini clamps.
That setup has adapters to 8mm hose for the carbs spigots.
Another bike got a grey hose from Yamiya. That sit very tight with simple thread clamps included.
Take time to get off.
Offline grcamna2
Re: Fuel Line Size
« Reply #7 on: May 30, 2023, 08:57:24 PM »
I get Gates brand,it holds-up for about a year+ before it gets dried out because of ethanol.
Re: Fuel Line Size
« Reply #8 on: May 31, 2023, 02:49:52 AM »
Gates Barricade hose should cope with that plus other chemicals.
That bike gets Shell V-Power with hopefully less ethanol.
Same hoses since early 2015 with countless of tank off-on since then. Not numbers of times...Dozens of times ;D
Offline grcamna2
Re: Fuel Line Size
« Reply #9 on: May 31, 2023, 09:26:09 AM »
I just checked Napa here locally and they have the 5.3mm/1/4" Gates Barricade fuel hose(not fuel injection)and they stock it.
Does that Gates Barricade hose resist Ethanol degradation ??
Re: Fuel Line Size
« Reply #10 on: May 31, 2023, 11:19:04 AM »
This is the one my blue K6 has
https://www.gates.com/gb/en/search.p.4219-000000-000000.html
Dual 6mm  hose from petcock.
Adapters to 8mm hose the carbs spigots.
Re: Fuel Line Size
« Reply #11 on: May 31, 2023, 05:39:07 PM »
Search for "5.5mm fuel hose". You can get it in 2-ft lengths, usually.
I buy lots more...
