Author Topic: CB750A pilot jets  (Read 1182 times)
Offline Fimlimbimjim
CB750A pilot jets
« on: June 05, 2023, 11:32:02 AM »
Hi all
Probably a silly question but here goes.
I have just purchased a 1977 CB750A. Now it shows the classic signs of some blocked pilot jets. However the exploded diagram I have from the workshop manual Show no pilot jets where I would expect them. That is where they are on other models and there are none in the carbs. I foolishly decided they were blank and undrilled so cleaned out everything else and put things back together. So no improvement.
Now I guess there are holes wot should be cleaned. If anyone has any cleaning tips or can let me know holes or not I would be very grateful.
Ta Jim
Jim
CB750 A 1977, 650 Transalp, PCX 125
K1200LT, R1200ST, R1100GS, R1100RT
R650 + sidecar (unattached), F800S
883 Iron
Offline newday777
Re: CB750A pilot jets
« Reply #1 on: June 05, 2023, 02:20:43 PM »
As you have? Stock PD44A carbs?? Then they probably have pressed in slow jets that need to be pulled out to clean properly.
I don't know the Automatic carbs to verify.
BTW welcome to the forum.
Go to the new members section and introduce yourself and your bike. Pictures are always welcome. Where are you located?
Stu
My current rides
Prior bikes....
« Reply #2 on: June 05, 2023, 10:57:42 PM »
Hi thanks for the reply.
From pictures of other carbs there are brass push in jets in front of th main jet. In my carbs and the CB750a pictures there is only the casting where I would expect the jet to be?
Confused Jim
Jim
883 Iron
Offline newday777
« Reply #3 on: June 06, 2023, 02:44:24 AM »
Confused Jim
Post pictures of your carbs
Stu
My current rides
Prior bikes....
« Reply #4 on: June 06, 2023, 05:47:59 AM »
Will do.
 Just fishing for an answer before I take them apart again. Trouble is I have 9 other bikes and they all seem to work themselves apart. Then I lose the bits  :)
Jim
883 Iron
« Reply #5 on: June 11, 2023, 03:28:28 AM »
Well of course the pressed in pilot jets are there (#38). Why I didn't see them for what they are Will have to be put down to old age.
Two were blocked one badly enough to need a tickle from a flame to loosen up the goop.
So back together, runs better now, nearly ticks over. No1 cylinder is a little lazy so another carb investigation there next weekend. Also the check valve in the bottom of the accelerator pump appears to be blocked I guess ultrasonic cleaning is in order?
Rock on
Jim
Jim
883 Iron
Offline newday777
« Reply #6 on: June 11, 2023, 05:49:22 AM »
Confused Jim
That's why you need to post pictures of your carbs....
There's a flat section on the head side of the intake throat that should have the PD numbers stamped in.
« Last Edit: June 11, 2023, 05:50:55 AM by newday777 »
Stu
My current rides
Prior bikes....
« Reply #7 on: June 18, 2023, 12:07:01 AM »
Thanks for the replies.
Yes standard PD44 carbs
Now the jets are clean it's running on all four. Needs a balance but not bad for now. So onto the accelerator pump and fast tickover valve thingy.
I'll keep my eyes open for this bit  :)
Jim
Jim
883 Iron
