Author Topic: oil in the gearbox cover  (Read 1611 times)
Offline _mark
« on: June 09, 2023, 05:57:04 AM »
Hello. I fully rebuilt my engine (changing roller and journal bearings as well).
After 20 minutes of running engine on neutral on the stand, I found the area of gearbox cover with a quite big quantity of oil (let's say 300 ml or half pint for US readers).
Is this normal? I ask for this because in the past, prior to rebuild the engine , in such area there was much less oil...
If is wrong what could be reason? thanks
« Last Edit: June 09, 2023, 06:00:29 AM by _mark »
Re: oil in the gearbox cover
« Reply #1 on: June 09, 2023, 10:12:40 AM »
The only thing I can think can give more oil is if the rubber end plug is missing in the oil transport to bearing cover.
It will pop and fly when using a water pressure washer cleaning the cases, outside as inside.
I have catched the plug and reinstalled.
If you want to sleep well, remove that bearing holder for a look. If missing, not good for gearbox where oil is transported.
See below where plug is in.
Offline Kevin D
  • SE Michigan
« Reply #2 on: June 09, 2023, 01:59:41 PM »
If it was dry it wouldn’t need a gasket on the cover or a seal on the shift shaft.
I can’t comment on your quantity of oil. I expect there is a passageway back to the sump.
There is a small o-ring on the bottom left of the bearing holder to keep oil flow to the trans shafts and clutch.
And as PeWe said a little rubber plug in the oil passageway from the pump to the bearing holder, I think it’s under the gasket.
I’m a little bit out of my pay grade here, I’m not an engine builder like many here. I have been inside of this cover just a couple times.
71 CB750 K1
107,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: June 09, 2023, 04:05:18 PM »
PeWe….. isn’t the rubber plug right there, under the gasket?
Kevin….. +1 to what you said.
« Reply #4 on: June 09, 2023, 04:25:10 PM »
There is supposed to be some oil under the cover. If you lean the bike to the side before removing the cover, less oil will run out.
The rubber plug is not necessary; neither my K1 or K7 motor have one. The gasket covers the hole, and the cover has an area that seals against the gasket.
« Reply #5 on: June 09, 2023, 05:16:31 PM »
This hole was open on the K0 engines, and shaped like a "D". In the K1 it received the little rubber plug (well, most of them from the Old Factory and almost all of the New Factory engines did) because the gasket weeped oil there from saturation with hot oil. The oil comes from the scavenge side of the pump, where it picks up hot crankcase oil. Part of this oil is sent here, and the rest back to the oil tank.
If the plug is missing and the gasket is well-sealed, it usually doesn't cause weeps. I've found, though, that if the oil gets real hot, like from 10w40 weight being used, and if the rubber plug is missing (or seriously shrunk from the years) it will again weep around this area, making a mess. I have sometimes gone to the trouble of drilling and tapping this hole shut with a real short, pointed screw (made from a 6mm screw, head cut off) to preserve the oil flow to the countershaft while also helping to seal it from a slightly-warped tranny cover.
« Reply #6 on: June 09, 2023, 09:30:54 PM »
Fully agree, John.
Only the o-ring as Kevin mentioned.
Again a good learning post whith good info.
I had no idea about no plug in early bikes.
« Last Edit: June 09, 2023, 09:34:01 PM by PeWe »
Offline _mark
« Reply #7 on: June 09, 2023, 10:50:06 PM »
Thanks everyone I will check for the rubber plug but I'm pretty sure is present.
3
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: June 11, 2023, 07:13:34 AM »
3
If it’s there, put it back together and ride!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: June 11, 2023, 08:02:20 AM »
Yet another great little learning session here!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline enwri
  • So that noise is normal?
« Reply #10 on: June 11, 2023, 08:57:04 AM »
I maybe confusing this with another bike, but is there a brass ring in the end of the  transmission shaft that the nozzle on the bearing retainer has to go through?
I have a memory of having to slide one back towards the end of the shaft because the nozzle didn't go in far enough to ensure the oil didn't just flow back out. When the nozzle is in far enough the ring creates a dam that forces oil inwards along the shaft.
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
« Reply #11 on: June 11, 2023, 11:54:53 AM »
I don't recognize that as a 750 feature(?). The 750 tranny countershaft is pressure-fed from the scavenge side of the oil pump via this little port, which feeds oil to the center of the shaft via this [fancy] bearing retainer casting.
Offline enwri
« Reply #12 on: June 12, 2023, 04:09:34 AM »
 Oh oh, it seems a lifetime of leaded fuel is taking its toll. "May the strongest affliction win."
OP, I got nothing more to add..
8? XJ 550 meh...
Offline _mark
« Reply #13 on: June 14, 2023, 08:44:36 AM »
Hi. Today I re-opened the cover and I found where this oil is coming from.
There is a window that makes communication between gearbox and side cover. Such window is near the shaft of the pedal of the gear shifter
Is such window normal?
Please note that after I drained the oil the first time, subsequently and up to today other oil (approximately 3/4 liter, see picture)  built up without cranking or igniting the engine. So it seems a "static" leakage. Could it be the check valve of the oil tank ?
Thanks
« Last Edit: June 14, 2023, 08:50:47 AM by _mark »
« Reply #14 on: June 14, 2023, 12:48:07 PM »
I had to check my 1975 block.
Same opening.
I have never had a thought about it. The gear shifter with stuff need lubrication
Offline _mark
« Reply #15 on: June 14, 2023, 10:34:09 PM »
Thanks PeWe.
Briefly resuming, is it correct that so much oil is going to flooding the lateral cover and that I'm too much overthinking about it ?
Consider that we are just above the oil pan.
thanks.
« Reply #16 on: June 15, 2023, 02:13:59 AM »
The hole must be oil return
