Author Topic: Kill Switch Numbers  (Read 513 times)
Offline Freebirdbeachbum
  • I don’t want a pickle, ...
Kill Switch Numbers
« on: July 21, 2023, 07:57:36 AM »
I'm trying to diagnose a no-spark issue and was looking at the kill switch as a possible source of the problem.
My continuity test of the kill switch with a multimeter yielded the following:
ignition off - 0 in all positions
ignition on - 1 in Run position; 4.15 in both Off positions
Not being one that understands the magic of electricity, can someone please tell me if these readings indicate a switch that is working or not.
Thanks.
1972 Honda CB 750
1980 Honda CX500 Custom
1968 Wards Riverside Benelli 125
2017 Triumph Tiger Explorer XRT
2021 Lance Havana Classic 125
1965 Moto Guzzi Lodola Gran Turismo
Offline BenelliSEI
  • 1969 cb750
Re: Kill Switch Numbers
« Reply #1 on: July 22, 2023, 05:31:58 AM »
Sounds more like you’re taking an Ohms reading versus a simple continuity test. I’d be more interested in voltage readings with the switch moved through the positions. You should see above 12.4v when in the RUN position with key ON.
+1. I like to check the voltage on the power lead, at the ignition coils. That feed comes through the switch and you essentially check the entire circuit.
