Author Topic: choke problem cb 750k2  (Read 689 times)
Offline olasek18_18@o2.pl
« on: September 19, 2023, 06:53:28 AM »
Hello Guys.
I have a problem with start my bike,
when I switch on the full choke, the motorcycle turns off,
the motorcycle does not increase the rpm on choke,
 it starts best without choke and with a bit of gas.
Some problem with carburetor channels or jet?
Offline smee
Re: choke problem cb 750k2
« Reply #1 on: September 19, 2023, 07:05:41 AM »
Need some more info from you.
What type of carbs do you have?
Is it stock or pods? What jets do you have in? Stock or aftermarket jets?
Carbs balanced and floats set to spec?
Could you be more specific regarding 'it starts best with a bit of gas?' Like blipping the throttle before starting? Shooting ether or starting fluid in the carb intakes?
Petcock/tank clean of debris? Do you have good flow of fuel to the carbs?
With the info you provided, it's most likely a carb problem. I will reserve any advice I may have until you provided us with more info.
« Reply #2 on: September 19, 2023, 07:40:14 AM »
Carbs Keihin 657A
serial airbox
main jet 120
slow 40
pilot 1 turn off
mac exhaust 4in 1
« Reply #3 on: September 19, 2023, 07:41:28 AM »
when starter run I just add little throttle
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #4 on: September 19, 2023, 07:46:09 AM »
The choke linkage does not affect the throttle position, only the fuel flow to the engine
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #5 on: September 19, 2023, 09:10:35 AM »
When engine is really warm after at least 30 minutes ride, set idle to 1200rpm.
This will work fine when riding. Even better take offs.
This make the engine easier to idle when cold too.
Mikuni Smoothbore VM29 has raised idle when using choke. This is by design.
Mikuni TMR has an on-off choke button to pull-push that gives 2000-3000rpm idle.
« Reply #6 on: September 20, 2023, 06:18:57 AM »
The chokes on the early 750's are prehistoric in design. I use mine just on cold start and flutter it back and forth as needed but usually it goes off pretty fast and the faster idle cam is in my wrist. Most don't like to keep running for long at full choke.
