Author Topic: Cb350-4 oil filter question  (Read 471 times)
Offline itsahonda4
    • www.wfomodels.com
« on: October 16, 2023, 06:57:23 PM »
Heya all, I’ve just commissioned a 350-4 1972 mode and
When servicing the engine I pulled the oil filter canister off and observed that the oil filter (std Honda, same as the 750’s) has an aluminum space about 1-5” long in what is otherwise an oversize oil filter canister. I read somewhere this was to increase the oil capacity of the engine. Both my canisters from 2 barn find bikes are damaged so I put an NOS CB750 canister and bolt on the engine and
Filled ‘er up and everything seems fine.
Is the increased capacity fact or fiction or
Is there another reason for this somewhat hillbilly arrangement?
Al
Re: Cb350-4 oil filter question
« Reply #1 on: October 16, 2023, 07:15:47 PM »
Al
There should be a large spring and a flat washer in front of the oil filter. This pushes the filter almost off the oil filter bolt as you go to screw the bolt into the boss on the front of the engine. Then the spring holds the filter right up against that boss when you snug down the filter housing.
An aside of advice: if you attempt to use the large O-ring that comes along with oil filters nowadays, it WILL leak oil from a warmed-up engine, dripping off the bottom of the filter housing. The proper O-ring is made for Honda and is so thick that you almost suspect it is too thick: that's the correct one. If the one you have just lays in the groove, even having some slack, it is the one used by Kawasaki and Suzuki (they used the same oil filter housing after 1978) and it should be replaced. Many of these oil filter housings get broken from folks tightening them too tight because of this issue: they just need to be snugged down, with the proper O-ring.
The difference is due to the type of oiling systems used in the other bikes: they are much lower flow and pressure than is found in yours. They all used the same housing because after the 750 was discontinued the vendor owned the rights to these parts.
Offline carnivorous chicken
« Reply #2 on: October 17, 2023, 07:45:49 AM »
Al
IIRC the 400F (some 400Fs?) has a shorter one, no spacer but a spring, and you can switch them out on 350Fs with no issue.
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: October 17, 2023, 03:25:31 PM »
I’m curious. My wife had a ‘77 cb400F for a long time and I don’t recall the oil filter housing being any different than our cb550K or cb750K. What is the actual difference?
Online bryanj
« Reply #4 on: October 17, 2023, 04:51:11 PM »
The 350 parts list at cmsnl does show a spacer and a different part number for the filter casing(333 midle number) meaning it was first used on the 350 four.
Perhaps Mr Honda though a little more oil woul be usefull on this tiddler
