Author Topic: Another project-1976 Honda CB550K  (Read 46495 times)
Offline denward17
Re: Another project-1976 Honda CB550K
« Reply #275 on: February 29, 2024, 07:10:22 PM »
Alternator cover installed ....
Painted the oil filter housing...
Cleaned valve cover, installed new seal and o ring on tach shaft, applied assembly lube to rocker arm pins and have valve cover ready for install.
Den,what condition do the rocker pins into the cam cover holes look like ?
They look good, no pitting, I didn't measure them but they all fit tight with no wiggle.
Offline grcamna2
« Reply #276 on: February 29, 2024, 07:55:25 PM »
 8)
75' CB400F/'bunch o' parts'
Offline Ozzybud
  • Honda Lover
  • Honda Lover
« Reply #277 on: February 29, 2024, 08:29:52 PM »
Engine is looking great.. good job
1976 Z50A PARAKEET YELLOW
1970 CT70  CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVIERA BLUE
1974 CB350F GLORY BLUE BLACK METALLIC
1973 CB350F FLAKE MATADOR RED
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Online newday777
« Reply #278 on: February 29, 2024, 10:05:15 PM »
Den
The alternator cover looks good installed. 👍
Stu
My current rides
Prior bikes....
Offline willbird
« Reply #279 on: March 01, 2024, 04:30:07 AM »
Looks good. At a past job we would deep clean the machines and the shop for tours, I would just clean the dirtiest thing first, then that made something else the dirtiest thing, and I would clean THAT, so on and so forth. Pretty quickly things started to look nice :-).
Offline denward17
« Reply #280 on: March 06, 2024, 01:49:12 PM »
Machine shop called earlier today indicating parts were ready for pickup.
Head resurfaced, cylinders resurfaced, bored for each piston.  Best I can tell with my archaic measuring methods, he hit my targets of .0006" per cylinder, maybe just a touch tighter.
All pistons slide in each hole, but requires some push.
Now to start cleaning up and painting both head/cylinder, install valves, check valves for leaks, install valves with new KW springs/viton seals.
Offline Mark1976
« Reply #281 on: March 06, 2024, 01:52:06 PM »
   Looks great!!!
Start with the end in mind...
Offline BenelliSEI
  • 1969 cb750
« Reply #282 on: March 06, 2024, 05:01:30 PM »
Nice to have everything back “date and sound”.
Offline denward17
« Reply #283 on: March 07, 2024, 04:36:05 AM »
It’s odd, your head does not look like the underside was fully surfaced. There are areas that appear to be “unmachined”. If it was surfaced by 0.006, the entire surface should look equally milled. At least I’ve never seen a surface milled flat that wasn’t fully machined…
Maybe it's the angle of the picture, but it was fully milled.
« Reply #284 on: March 07, 2024, 07:05:47 AM »
"he hit my targets of .0006" per cylinder"
Hey Cal...Denward was referring to the boring, but I get what you're saying, in the pic, the right side of the head does not appear to be fully milled.
Offline denward17
« Reply #285 on: March 07, 2024, 07:53:47 AM »
I did have a shop light hanging just over the pieces, that may skew what it actually looks like.
Here's another pic without the shop light.
Offline denward17
« Reply #286 on: March 07, 2024, 12:04:07 PM »
Cylinder cleaned up and painted.......
Working on some rubber plugs to see if I can setup some type of vacuum device with my Mityvac to test valve seat leakage.
Offline BenelliSEI
  • 1969 cb750
« Reply #287 on: March 07, 2024, 02:33:03 PM »
Dennis….. No need for that. The “tried and true” method is easiest. Assemble the valves and springs. Screw in a set of spark plugs. Turn the head upside down and fill each combustion chamber with gasoline or varsol until the valve heads are totally covered. Wait five minutes and check each port. Nothing leaking through? You’re good to go. If any seep, take a bit of fine lapping compound and lightly seat the valves by hand.
Offline denward17
« Reply #288 on: March 07, 2024, 03:47:32 PM »
Thanks John, but I might as well try it while I am at this stage.  I keep reading where people mention the vacuum test, and I want to prove to myself that either is fine.  I did a quick test this afternoon on a couple of valves (already lapped), but I didn't have the springs on.  They both slowly leaked down with the vacuum test.  I will try tomorrow with the springs on just to see, and then fluid.
Offline BenelliSEI
  • 1969 cb750
« Reply #289 on: March 07, 2024, 03:52:28 PM »
I’ve always installed the springs. Never done it any other way.
Offline Mark1976
« Reply #290 on: March 07, 2024, 05:06:23 PM »
   With the vacuum test there's always a degree of leak down (valve guide and seal). Doing it the way john mentioned with the springs installed will let you know if there's a good seal at the valve face and valve seat interfaces.
Offline denward17
« Reply #291 on: March 07, 2024, 05:30:25 PM »
^Good point about the valve guide seal, I have not installed those yet.
Offline denward17
« Reply #292 on: March 08, 2024, 02:28:24 PM »
Got the head together today, new KW springs, Viton seals.
Valves were lapped in and did not leak with fluid.  I tried to use a MityVac to check with vacuum afterwards, and most valves held about 20HG, but slowly leaked.  I am pretty sure it was the apparatus I was using to insert in the ports.
Will paint next week.
Put it aside to work on a dang aggravating EGO battery powered mower, blades will not start.  Project for tomorrow.
Offline Mark1976
« Reply #293 on: March 08, 2024, 03:11:59 PM »
   Looks great...
Offline BenelliSEI
  • 1969 cb750
« Reply #294 on: March 08, 2024, 04:34:39 PM »
Nice work.
Offline denward17
« Reply #295 on: March 11, 2024, 02:37:14 PM »
Head cleaned/painted ready for install.
Next job is checking ring end gap and filing rings, starts tomorrow.
Offline denward17
« Reply #296 on: March 12, 2024, 01:22:57 PM »
Checked ring end gap today, had to file a few.
Top and 2nd ring end gaps are set to .007-.008",  left 3 piece oil rings as they were ~.009".
Rings installed on pistons, pistons installed on rods with assembly lube on wrist pins.  Rings staggered and oiled.
Plan to install cylinder block and head tomorrow.  Cylinders have been wiped with acetone at least 5-6 times with paper towels remaining white.
Will wipe one more time with a cloth before install.
Offline grcamna2
« Reply #297 on: March 12, 2024, 01:28:42 PM »
Moving along well Dennis  8)
Offline Mark1976
« Reply #298 on: March 12, 2024, 02:59:40 PM »
Clean is good.....
Looks great...
Offline denward17
« Reply #299 on: March 13, 2024, 01:51:36 PM »
Cylinder/head installed today....
Will loosen head bolt torque tomorrow and retorque.
