Author Topic: Another project-1976 Honda CB550K  (Read 46470 times)
Offline denward17
Re: Another project-1976 Honda CB550K
« Reply #400 on: April 27, 2024, 05:53:05 AM »
I did this.....
Just enough that you cannot see metal when the lid is latched.
Offline denward17
« Reply #401 on: April 29, 2024, 05:04:48 PM »
All dressed up and no where to go.......
I do have a DMV inspection agent coming tomorrow to perform the inspection, so hopefully within a few days I can get it registered and get a tag.
Offline newday777
« Reply #402 on: April 29, 2024, 05:08:10 PM »
Lookin good Den
Stu
My current rides
Prior bikes....
Offline grcamna2
« Reply #403 on: April 29, 2024, 05:49:32 PM »
Yeah Man  8) 8)
75' CB400F/'bunch o' parts'
Offline Mark1976
« Reply #404 on: April 29, 2024, 08:06:57 PM »
How do ya not like a bike that shines like that!!!
Start with the end in mind...
« Reply #405 on: April 29, 2024, 08:45:34 PM »
great job!
Offline denward17
« Reply #406 on: April 30, 2024, 03:36:41 AM »
Thanks Guys, that means a lot.
The bike does have a few warts here and there, but should make a good rider.
Offline BenelliSEI
  • 1969 cb750
« Reply #407 on: April 30, 2024, 04:31:27 AM »
Buffed out and sporting trim.....
Wow…. Been away a few days and missed the finish. Looks GREAT!
Offline denward17
« Reply #408 on: April 30, 2024, 11:08:22 AM »
DMV inspection passed, got tags and went for a bout a 10 mile shake down ride.
Got some tuning issues, seems like a little rich on the low end.
Will research and tinker, it did ride good, different feel from the 750.
Offline newday777
« Reply #409 on: April 30, 2024, 11:21:00 AM »
Den
They run better in the higher rpms apposed to idling in city traffic.
Stu
My current rides
Prior bikes....
Offline Mark1976
« Reply #410 on: April 30, 2024, 11:48:30 AM »
How does it start and run cold vs hot....
Offline denward17
« Reply #411 on: April 30, 2024, 01:15:31 PM »
Both hot and cold were pretty good, when it got up to temp I had to turn down the idle a little bit.  I did notice coming into the neighborhood in 2nd gear doing about 25 mph, it started burbling a little.  I reached down and pulled up the choke and it almost died.
Offline Mark1976
« Reply #412 on: April 30, 2024, 03:30:32 PM »
   If buy burbling, do you mean it stumbles, off idle or when transistioning from on to off throttle?
Offline denward17
« Reply #413 on: April 30, 2024, 04:03:20 PM »
I could tell it was rich, kind of like a stumble when trying to go on throttle just a little bit, just to hold even speed.
I going to try a 1/8 turn in on the idle mixture screws before I go back out with it.
Offline Mark1976
« Reply #414 on: April 30, 2024, 05:12:18 PM »
   Well, I'm not familiar with the delkevic pipe, so I can't speak to how it may be affecting your situation. But, the idle mixture screws don't have that much of and impact on a condition like your experiencing, they might help point you in the appropriate direction. If it gets worse after it's good and warm (hot), it's a smidge on the rich side. First thing I always check is floatbowl level, a slightly high level can cause a hot rich condition. Your running 38 pilots? Pull a plug if its rich at idle it'll show.
Offline denward17
« Reply #415 on: April 30, 2024, 05:20:20 PM »
Running stock jets and pilots, stock airbox, just Delkevic pipe with baffle in.
Plan is pull a couple of plugs later, troubleshooting a turn signal issue first.
Float bowl level was checked last week, all good there (clear tube test).
« Reply #416 on: May 02, 2024, 07:23:46 AM »
Thats the nice thing about the 550, easy to adjust idle on the fly!   I'd ride it about 100 miles and see what issues persist...
Offline Little_Phil
« Reply #417 on: May 02, 2024, 08:06:18 AM »
Well done getting it back on the road. If you feel it is good enough give it a 15-20 mile steady ride and then sort out the niggles.
Offline denward17
« Reply #418 on: May 05, 2024, 10:12:30 AM »
Turn signal repaired with a new unit from PartsNmore; turned out to be 2 issues:
Where I soldered the loose connection, I think it was starting to ground out the power and blowing main fuses,
I thought the green ground was plugged in sufficiently (connected to the inside of fork ear), but it was loose as well, causing intermittent flashing.
After fixing these all lights are working properly.
I do like the 4into1 Delkevic exhaust system, but decided to order the Delkevic 4into4 system.  Hopefully will be here late next week.
Pictures to follow.
Offline denward17
« Reply #419 on: May 07, 2024, 11:31:57 AM »
Put about 35 break in miles on it today, ran good.  After carb adjustment (air/fuel screws) it seems to run little better, but will keep tweaking until I get it close.  I think I am 2 full turns out, maybe about 1/8 turn out now and try.
And the good thing, I see no leaks anywhere, just hope that maintains.
I did spot what appears to be a little gas coming out of the overflow tubes, I saw nothing running out while it was parked, but did notice when I got home and layed on the floor to look underneath, there was some wetness on a couple of them.
Offline denward17
« Reply #420 on: May 07, 2024, 11:43:08 AM »
Does the 550 tick louder than the 750?
Mine seems to, take a listen:
NOTE: After 25 miles, ambient temp 85 degrees F, running Rotella T4 15w40.
https://photos.app.goo.gl/qJJ2Yq9sgdgTQGWj9
« Reply #421 on: May 07, 2024, 04:36:13 PM »
I would say that is loud enough for concern...I suggest opening exhaust valve inspection cap with the engine running,  You should see quite a good `splash in there..but I have never tried this with a 550 so can't get too specific.   Also double check valve clearance please.   I have heard sohc that loud and that was the sound of severely damaged camshaft
Offline grcamna2
« Reply #422 on: May 07, 2024, 06:21:47 PM »
Have you adjusted your valves & synched the 4 carbs ?
Offline denward17
« Reply #423 on: May 07, 2024, 07:20:21 PM »
I adjusted the valves during the head install procedure, but will check them again before it is cranked up again.  I did sync the carbs, just got them close so I could start it, will need to do that again as well.
Next startup I will take a couple of the caps off to make sure oil is getting to the top end ok.
Offline grcamna2
« Reply #424 on: May 07, 2024, 07:39:41 PM »
How did your valve guides feel,not too loose of a fit with their orig. valve stems?
The guides will wear in an oval pattern:front to back.
I also like to make sure each valve goes back in the same position/cylinder it was removed from.
