Author Topic: Petcock leaking, another don't overlook the easy fix.  (Read 737 times)
Online Don R
« on: April 24, 2024, 03:52:47 PM »
  So I have this cb750K2 with a leaky petcock, I don't ride it much and am trading it to my brother for an engine I don't want, therefore it needs fixed. I rebuilt it recently but bought another kit, obviously made in china. I removed the valve, sanded the tank bottom, cleaned the petcock top, replaced the o ring, put it back in.  Now it has aluminum tank screw to petcock body washers. They leaked through, I greased them and overtightened them with my JIS screwdriver. They finally appear to hold but the sediment bowl still leaked. Several different tries and o rings later, I left it turned off and blew into the gas line. Fuel sprayed sideways out of the sediment bowl. L0L!
 There is a tiny pinhole in the bowl. I swapped it with another one and, it's finally fixed.
Offline Johnie
Re: Petcock leaking, another don't overlook the easy fix.
« Reply #1 on: April 24, 2024, 04:47:46 PM »
Atta boy Don...don't those issues just drive a guy nuts. Nice job!
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #2 on: April 24, 2024, 04:52:50 PM »
Those original fiber washers are expensive but do work, i also had hit and miss results with alloy washers, even the ones with rubber inserts known in uk as "Dowty Washers"
Online CycleRanger
  • No comment about being an
« Reply #3 on: April 24, 2024, 07:34:48 PM »
Yep, I have run into that. Pin hole in the sediment bowl from corrosion over time.
Offline newday777
« Reply #4 on: April 25, 2024, 02:16:59 AM »
I'll have to put an air air pressure test to the one I cleaned up last year that was very full of powder when I took it off the tank. It cleaned up well in the ultrasonic cleaner amazingly. (I thought I had pictures of it after cleaning but will take new pics and post later)
Stu
My current rides
Prior bikes....
« Reply #5 on: April 25, 2024, 03:41:08 AM »
i use copper washers,work fine.
Offline newday777
« Reply #6 on: April 25, 2024, 11:47:03 AM »
The ultrasonic cleaning results
Stu
My current rides
Prior bikes....
