Author Topic: 400F. Lost Key. What Does One Do In 2024?  (Read 884 times)
Offline Hailwood1965
« on: May 31, 2024, 05:48:20 AM »
I'm hoping I have merely misplaced my key but I may have lost it.
What are the options to get a new key? Or new ignition?
Also, the seat is closed. How would I get it open if I bought a new seat lock and key?
Thanks much
Offline denward17
Re: 400F. Lost Key. What Does One Do In 2024?
« Reply #1 on: May 31, 2024, 06:15:32 AM »
Welcome to the forum....
Somewhere on the ignition switch and seat lock, there should be a number code of the key, you can search that number and probably find a used key on ebay.
Offline CycleRanger
  • No comment about being an
« Reply #3 on: May 31, 2024, 08:12:01 AM »
Hello!
Another source for keys.
https://www.hondakeys.com/
Offline willbird
« Reply #4 on: May 31, 2024, 12:28:54 PM »
Thanks much
Also I think you can just unbolt the seat latch reaching up and using an extension and probably a 10mm socket ??
« Reply #5 on: May 31, 2024, 01:41:33 PM »
Okay. I was able to get at the key cylinder. I'm new here and hope the photo I am posting does post ... So I am looking for Honda key # 70809 ?
Online grcamna2
« Reply #6 on: May 31, 2024, 02:00:07 PM »
Yes.
The numbers were always etched/stamped into the case;certain Japanese bikes required lots of cleaning-off the outer switch case to find it,as the manufacturer can hide them,which is a good thing.
« Last Edit: May 31, 2024, 03:03:31 PM by grcamna2 »
75' CB400F/'bunch o' parts'
« Reply #8 on: May 31, 2024, 02:57:19 PM »
THANK YOU!!
I'm pretty sure the way it works is that the moment that you buy a replacement key the misplaced  one shows up ...
Online grcamna2
« Reply #9 on: May 31, 2024, 03:04:59 PM »
Spares are good  ;)
Good deal on the key !
« Last Edit: May 31, 2024, 03:29:42 PM by grcamna2 »
« Reply #10 on: June 03, 2024, 08:00:35 AM »
https://www.ebay.com/itm/204137714829?epid=1711837161&itmmeta=01HZ89SBTRFAJ8J9Y7TQ6M6Y4V&hash=item2f878e548d:g:Q4IAAOSw8Q5mFELS&itmprp=enc%3AAQAJAAAA4HV87p2NJU%2FDWhSlQmESLnofOmlFxyY9i60eWEniMkhAiziOTx6eZJgH3zfyZAQFbWDTMehodcSIzoum80oFd%2Bc25A1AD609hz%2BTm01DVULumPkgPlwBwOiSmkrdadgjN8nwiGvJz%2FeWj3eVtfFn5Sx7%2BvYFE%2BgN0v9bXd9KG%2FHbiIwjSckGF9T5vLtKnYo3pxU%2Fl3uafz%2BReD2acNueSDF3q12Tf6Sdbd3zc4Us0Uq8Sy0nZXjhV9%2Bbqu2ULLkzSe%2BELFnzecFEvxn5TtfbOKQS%2FWTJ8vNSexr6%2FaBRJPO%2F%7Ctkp%3ABk9SR7i95Yn6Yw
There you go.
Even cheaper.
https://www.ebay.com/itm/232325875335?epid=1711837161&itmmeta=01HZ89SBTRJ5VSC5PJM4CFMWB5&hash=item3617b38687:g:a0EAAOSw8GtZRKct&itmprp=enc%3AAQAJAAAA4Abv3rYSqWd5gFKIrDeQKNuVf1lA6AZ4elSFEsWTD6ce7uBzzw%2F4FMufDI%2FPCUUqydk7NwYpxTifPEVBOvGhRtkn0HkRUeXbv5beUzn7G03fU9mvWbNhClx0PIa984n7esaQt%2FF9%2BbWJR9d8%2FY25QxQ%2BlMWODpXgwbpqnW6VdVSti0WnSl7km%2F4Nq3AA%2Fpdp1WMO6owPAJyBPcmNKec%2BqBZPqBd9Tkzr04d4wagO%2BKgcaW143NwI50SGGpyNCiSFbmSkYzkeN6p6H02QCt6wL4GZMqyIlUZZ7KYTs6dtP7d4%7Ctkp%3ABk9SR7q95Yn6Yw
I've never paid over 12 bucks for a replacement key...
https://www.ebay.com/itm/225813290396?itmmeta=01HZF9QXT81FBMA2PZ5J9D94YA&hash=item3493855d9c:g:8O0AAOSwgodlJsU0&itmprp=enc%3AAQAJAAAA4B1Caau9MzalyGHuHt6hz8s6m5qBn1zUS7a6aheQotcdRbi1LVuYSssCdfk35MtA37dWuAZUe1U5o2sgjXrAI15dfRaYjKcR3yJMgLpraoklo02In69aKw8fK6BSrmDiR8L%2F9vDMkgvtm%2F8zBqPtVlWAcuq%2ByqleVfxpPtGABFZEeksraqbZNEB%2FFxZzMgWyez%2BGS8eBDZE7k1KBMpo9XTUq4FhzPo0Awd%2Fk9Nl2v7YIDs2epzpGlWO%2FroeIU6lokkZLbfAFzuMmeaANmKduwB77x8r%2Fm8a3WTq6NDSweLVe%7Ctkp%3ABk9SR5rd3-n7Yw
« Reply #11 on: June 03, 2024, 02:45:36 PM »
Dan Kyle's old shop??
Dan is dead and has been for years. I had no idea they were still operating under his name.
« Reply #12 on: June 03, 2024, 05:38:25 PM »
There you go.
Even cheaper.
I'd bet about $5 of that is postage! :(
« Reply #13 on: June 04, 2024, 07:06:13 PM »
The replacement key has arrived and all is well.
« Reply #14 on: June 04, 2024, 07:39:49 PM »
And now you will find the original!
