Author Topic: remove steering lock  (Read 3724 times)
Offline cost261
« on: August 07, 2024, 10:30:10 AM »
any one  has good way to remove cb 550k steering lock thank
Re: remove steering lock
« Reply #1 on: August 07, 2024, 11:26:35 AM »
do you have the key?
Offline CycleRanger
  • No comment about being an
« Reply #2 on: August 07, 2024, 12:00:16 PM »
Hello!
The easiest method is to remove the plastic cover then insert the key and remove the lock.
If you lack the key get the number off the face of the lock and buy a new key.
https://www.hondakeys.com/
There are also ebay sellers etc. who have original keys as well just search for the key number.
Lacking a key to remove the lock you either have to pick it, or pretty much destroy it.
Offline cost261
« Reply #3 on: August 09, 2024, 08:43:56 AM »
Can't find code on it lock face I don't see how remove neither. Any pics how.  Tanks
Offline CycleRanger
« Reply #4 on: August 09, 2024, 08:51:40 AM »
What year bike do you have?
Offline cost261
« Reply #5 on: August 09, 2024, 01:55:08 PM »
1976 550k
Offline CycleRanger
« Reply #6 on: August 09, 2024, 03:22:45 PM »
Here's a diagram. Remove the screw (#49) and remove the plastic cover.(#28)
You should be able to see the face of the lock then.
It should have a letter followed by numbers on the face.
That is the key code.
Once you insert a key and turn it the lock mechanism pulls out. (#30)
Don't lose the little spring. (#31)
Offline cost261
« Reply #7 on: August 10, 2024, 08:08:02 AM »
Thank for the diagram. Looking at lock face there isn't letter or number. My next step i guess is take lock out. How? I have no idea. Suggestions ???
Offline Oddjob
« Reply #8 on: August 10, 2024, 08:18:26 AM »
You sure? Not seen one of those locks that didn’t have it stamped on the face.
Just drill the lock out if no key.
Offline CycleRanger
« Reply #9 on: August 10, 2024, 08:28:56 AM »
The lock is held in place by a small roll pin and can't be removed intact without being turned.
Since the lock is difficult to access without removing the forks and or triple tree I would try picking the lock first. They are simple locks, pretty easy to pick.
After that, drilling is an option but again it's difficult to access because of the location.
Also, I assume you only have an ignition key because the ignition switch was changed.
Do you have a key for the seat lock?
The original seat lock and fork lock would have had the same numbers.
On the later seat locks the number is stamped on the back of the lock.
« Last Edit: August 10, 2024, 08:34:00 AM by CycleRanger »
Offline Oddjob
« Reply #10 on: August 10, 2024, 09:17:33 AM »
Good shout regarding the seat lock, all new bikes of this era were keyed alike and it’s a good chance the seat lock will still match the steering lock. As for drilling it out, just remove the front wheel and the fender and you’ll have sufficient access to drill it out, then just use a screwdriver to turn it whilst pulling outwards.
Offline cost261
« Reply #11 on: August 10, 2024, 11:07:07 AM »
Weekend. I will try. Let you know soon. Thank very much. Peace
Offline cost261
« Reply #12 on: August 23, 2024, 07:47:54 AM »
I watched tons videos how make impressions key. After scraped 4 new blanks. Finally got right cuts. BOOOOM . Open the lock.
Offline CycleRanger
« Reply #13 on: August 23, 2024, 08:16:05 AM »
Excellent!  :)
Glad you were able to get it out intact.
« Last Edit: August 23, 2024, 08:17:48 AM by CycleRanger »
