Author Topic: New here, hello!! Introduction  (Read 1423 times)
Offline Polareyes
  • New owner of my first bike, a 73 Honda CB350f
« on: August 10, 2024, 02:07:04 PM »
Hey all, I was advised by sohc which I found from a user in a Honda CB subreddit. Working my way thru the internet trying to find help and good advice. I recently (kinda) bought my first bike. She’s a 73 Honda CB350f. I searched for her specifically, so I (mostly) knew what I was getting into. I’ve worked on cars for some odd 20 yrs so I have a good mechanical knowledge background - just not with bikes. I’m aware I’ll need to learn a lot and I’m more than willing to do the work. I’ve had a lot of trouble since I brought her home, so I have a lot of questions . She ran great, looked good, but needed new tires (her shoes were 40 yrs old! How?!?) and front brake lines/caliper/pad. Everything went smoothly until I got her in for her appt for her tires. I got her back and her rear brake rod was bent in 2 different places, the brake arm wasn’t even fully attached, the spacers were on the wrong side, axle was in backward 😭. Got all that fixed and a refund, the owner took care of it personally, did real well by me. Thing is, since then I’m leaking gas with the petcock closed, pours out when it’s half open - but has a brand new carb kit 🤷🏼‍♀️. Also, forgive me bc I’m still learning terms. The valves under the fuel bowl have cut off hoses, so the fuel drips on my engine - no idea what I’m supposed to do there. Ik they clearly need runoff hoses put on, but where do I connect the other ends? Did an inspection of the wiring due a whole other clusterF and found corrosion around the connector where the master harness meets the regulator. So I’m putting in a new master harness right now and I got a new reg/rec but I have a few questions abt that too 😬
Anyway, I love her and I know these problems came up aren’t her fault. But I’m dying to get her on the road!! She ran so smooth and beautiful when I took her around the block on those 40 yo tires 😅
Thanks in advance!! Everything helps!
In case I forget on posts, I have a 73 Honda CB350f and she’s my first bike
Offline Alan F.
Re: New here, hello!! Introduction
« Reply #1 on: August 10, 2024, 02:41:28 PM »
Welcome from Boston. You're in the right place to ask every question and get answers that will fill in every detail. We love pictures too so start a thread in the Project Shop and chronicle your bike"s transformation there, its also a great place to park information you want keep handy.
Offline Mark1976
« Reply #2 on: August 10, 2024, 02:51:03 PM »
   Welcome aboard, and always great to have a new member.  You'll get your bike back up and running,  one thing at a time. Congrats and good luck.
Start with the end in mind...
Offline denward17
« Reply #3 on: August 10, 2024, 03:02:00 PM »
Welcome from NC, good people here...
You can post your questions here:
http://forums.sohc4.net/index.php/board,2.0.html
Offline grcamna2
« Reply #4 on: August 10, 2024, 03:33:26 PM »
Welcome to this forum;lot's of helpful,knowledgeable folks here who will help you gain the repair skills you enjoy doing.
What type of automobiles have you worked on in the past ?
75' CB400F/'bunch o' parts'
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
« Reply #5 on: August 10, 2024, 05:51:59 PM »
Welcome from Minnesota,
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Offline tool14
« Reply #6 on: August 13, 2024, 02:20:56 PM »
welcome aboard
« Reply #7 on: August 13, 2024, 09:19:19 PM »
Welcome!
Do you have, by chance the original parts for the carbs BEFORE the rebuild? You'll probably need them, don't lose them. The brass jetting parts are EXTREMELY rare, and 100% of aftermarket "kits" don't have the correct parts.
Those hoses on the bottoms of the carbs: Honda sells it (3.5mm carb hoses, in bulk). They run from the bottom of each carb to back behind the engine, to hang about 6"-7" off the ground. The intent to to route any spilling gas AWAY from the hot engine, and behind and below it.
Look inside the gas tank for rust, dirt, corrosion and other nastiness. That stuff can make the float valves in the carbs stick open, which overflows the carbs, which makes the gas come out those little nipples on the bottoms of their float bowls - onto the engine, if the drain hoses are missing!
