Author Topic: Flash Rust Tank  (Read 1153 times)
Offline grumpy56
Flash Rust Tank
« on: September 17, 2024, 03:47:05 PM »
Was surprised to see this flash rust in my CB400 tank. It seemed to just recently appear. Same thing on my GT380 although to a lesser degree. What is your recommendations for cleaning it and preventing it from happening again? Thanks.
Offline Kelly E
  • Geriatric Hooligan
Re: Flash Rust Tank
« Reply #1 on: September 17, 2024, 03:51:47 PM »
I use EvapoRust to get rid of the rust and rinse several times with diesel. The diesel will prevent the flash rust until you use it. I just can't use water to rinse a derusted tank, it seems so wrong. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline grumpy56
Re: Flash Rust Tank
« Reply #2 on: September 17, 2024, 08:02:15 PM »
Evapo-Rust does work well and it does seem wrong to slosh H2O in your de-rusted tank doesn't it!!!!
Offline BenelliSEI
  • 1969 cb750
Re: Flash Rust Tank
« Reply #3 on: September 18, 2024, 05:24:01 AM »
I rinse with a bit of diesel fuel mixed with Avery small amount of 2-stroke oil.
Offline ZingZing
  • Backroad Blunderer
Re: Flash Rust Tank
« Reply #4 on: September 18, 2024, 01:50:37 PM »
Vinegar is cheap and it works or you could also make your own evaporust at home.
To prevent rust in the future you could line it with POR-15 or something like that but that seems like a pain. If you're going to use the tank immediately I'd just fill it up and try to keep it filled as much as possible.
"A droplet received in need will be repaid with a whole spring, a spark of hatred will result in the burning of an entire forest!" -Fang Yuan
Offline grumpy56
Re: Flash Rust Tank
« Reply #5 on: September 23, 2024, 04:21:39 PM »
The rust inside rubs off with my finger. For now, I just put some Mystery oil in and filled the tank. Rust spots still there but I don't think they are going to cause a problem. I do have a see-thru fuel filter installed on the gas line. Do appreciate your comments.
