Author Topic: Cleaning SL350 K0 Black Carbs  (Read 1485 times)
Offline pjandrew99
« on: September 23, 2024, 02:47:22 AM »
Usually, clean carbs in ultrasonic cleaner with a water/simple purple mix. Worried that it will remove the paint and wondering what would be safe to use.
Also, if I go the ultrasonic cleaner route, do I need to punch out the emulsion tubes or can I leave them in. So far, the carbs have been pretty clean aside from some sediment in the bowl. Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Online newday777
Re: Cleaning SL350 K0 Black Carbs
« Reply #1 on: September 23, 2024, 04:13:36 AM »
The carbs didn't come black from the factory.
Paint will come off in the ultrasonic/heat or carb dip soak cleaner. Even spray cleaner on the paint will strip the paint.
Stu
My current rides
Prior bikes....
Offline pjandrew99
« Reply #2 on: September 24, 2024, 05:47:40 AM »
Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
« Reply #3 on: September 26, 2024, 07:57:30 PM »
They will also work a lot better when they aren't coated in paint. ;)
Look for tiny plugged-up vent holes, I think the first SL350 (with the CV carbs) had 1 on the inside of each carb body.
Offline pjandrew99
« Reply #4 on: September 27, 2024, 05:59:06 AM »
Thanks!
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
Offline CycleRanger
  • No comment about being an
« Reply #5 on: October 19, 2024, 05:15:11 PM »
Actually I believe the SL350K0 did come from the factory with black carbs. But it was just paint.
Offline pjandrew99
« Reply #6 on: October 20, 2024, 01:50:32 AM »
Did a bit more research and yes they did come in black that year. I did run them through the ultrasonic cleaner with a bit of LPS Precision cleaner. Paint stayed on fine but took a bit of sheen off the finish.
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
