Author Topic: Rebuilt engine TWICE, effing thing still leaks oil.Just about done with this bik  (Read 8886 times)
Offline stueveone
congrats!
Offline kghost
I Pm'd the details on the PCV valve.
I just routed it to the stock airbox.
Stranger in a strange land
Offline coolcat2002
I think the moral of this story is clear:  Get a Bmw R90/6. :P
What....the 100 series suck? :D
Offline dramsell
What is a gordon frame kit?
Dave R
Offline Sweep
  • Just remember there are no stupid questions, just some idiot asking them.
For those of us that aren't using the airbox (like me with stacks) I have a harley building trick I'm planning on employing.  I'll drill the holds in the tappet covers and install a Harley shovelhead oil crossover fitting and connect a hose to that, which will be capped off by a small breather.  The only problem here is that sometimes oil can leak from the breather so if there's room I'll put the breather in a coffee can or hopefully something smaller if I can find a place to hide it all.  Every once in a while just drain the can, it's worth a shot eh?
'76 cb750K Wiseco 836|ape crank/head|Carillos|CR29s|Dyna 2k|Kerker
'74 Norton Commando Fastback w/belt and bells
Offline Wheelhorse77
  • She's got some Juice
For those with the 4-1; has anyone ever tried to scavange the crank pressure by routing the breather into the collector of the 4-1 for those who have that set up?
Use the venturi to pull the vapors from the crankcase and increase hp.
77 750F2 ressurected from the dead
ASE Advanced Level Master Tech
Offline edbikerii
    • Gallery
Yes, I've read about that in an old auto racing exhaust design book.  In order to maximize the venturi effect, the tap would have to be welded in at the narrowest point in the exhaust, which I think would usually be the collector on 4-1s on most bikes.
I would be concerned about backfires in the exhaust pressurizing the crankcase, and possibly blowing out oil seals, etc.  Perhaps a check-valve would prevent this.
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline dusterdude
thats why you use an air pump check valve off an old chevy.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
That's why they invented the PCV valve for the pcv system---to stop pressure going back in for one and to prevent just what you have described above...fire in the hole...
I have seen this happen, where students have installed the pcv in the wrong direction and have blown all of the gaskets due to a backfire; not good!
In 600 hp applications, where cars have converted to exhaust driven ventilation, I have seen a quick 20-40 hp picked up depending on whose dyno and the individual application.
It would be interesting to see if anything is gained on the upper RPM band for an 836 kit.
Offline edbikerii
    • Gallery
Yes, I've heard that the increased vacuum helps the rings seal better, thus improving horsepower.
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Thought and proven process is that the pistons don't have to also compress air on the way down on the Intake & Power stroke. The vacuum, in a sense, aids in drawing the pistons down.
