Author Topic: Exhaust swap from ‘76 to ‘77  (Read 585 times)
Offline la ca fe
« on: January 02, 2025, 06:37:42 AM »
I’m going to put on a set of ‘77k stock exhaust pipes on my ‘76 cb750k. I found them hanging in an old abandoned barn here in N. Carolina that is getting ready for a developer to tear down to make room for “progress”. The guy who took them off of his bike must have done it the day he drove his new bike home to his farm from the dealer. I cleaned the up and have yet to see a set so perfect! With a simple modification, I can run them on this ‘76k I have that needs an exhaust.
I have stock carbs and airbox my ‘76. Will I need to change any adjustments to my carbs to accept these ‘77 pipes?
Anyone here done this before?
Thanks!
1976 cb750k
1976 cb750f
1975 cb750f
1970 cb750
1977 xs750
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Exhaust swap from ‘76 to ‘77
« Reply #1 on: January 02, 2025, 06:43:57 AM »
I'm sure others will chime in, I suspect some sort of jetting or needle setting will be needed.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Online newday777
« Reply #2 on: January 02, 2025, 10:37:34 AM »
Congrats
You probably won't have to rejet but you won't know until you get them mounted and do some plug chops to be sure that it's burning properly.
You will need to make some rear mounting bracket modifications as the 77 has a longer frame than your 76 and earlier K frames.
Stu
My current rides
Prior bikes....
« Reply #3 on: January 02, 2025, 10:56:34 AM »
Plus the -77 stuff with studs etc attaching the pipes to the head. Not old style spigots as K6 had stock.
« Reply #4 on: January 02, 2025, 02:10:53 PM »
Like PeWe said: those K7 pipes mount differently. They will likely be fine with the jetting you have: if the plugs run a little bit dark then turn the air screws inward a little, like 1/8 turn. The K7 has PD style carbs for emission control reasons, and they mix differently (especially during deceleration), so those pipes were designed with a bit more restriction than were your original pipes - to go with those PD carbs.
Offline la ca fe
« Reply #5 on: January 02, 2025, 03:10:23 PM »
Thanks for the comments and info, looking forward to getting started.
1976 cb750k
1976 cb750f
1975 cb750f
1970 cb750
1977 xs750
Offline Kelly E
  • Geriatric Hooligan
« Reply #6 on: January 02, 2025, 04:03:59 PM »
I like your KFC bucket. I have the Colonel himself. I got him when they closed down the KFC nextdoor. They were going to throw him away until my buddy and I rescued him from the demolition dumpster about 2am after tequila Tuesday back in the early 80's.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline BenelliSEI
  • 1969 cb750
« Reply #7 on: January 03, 2025, 06:39:39 AM »
Let us know how this turns out. I have a good set hanging outside my shop and keep “wondering”. Do you have the plates that tie the pipes to the rear foot pegs and frame. Pretty unique part!
