Author Topic: to keep or not to keep 'hard lines"??  (Read 1631 times)
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« on: March 28, 2007, 07:06:25 AM »
I'm about to order some speigler braided lines to finish my dual disk setup, and I am "him-hawing" over keeping the 9" hard lines into the calipers as to keep the lines inside the fork tubes for a nice clean stock look. OR just run them right into the calipers and avoid the extra fitting... any thoughts/ experiences??? :-\
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Offline tsflstb
Re: to keep or not to keep 'hard lines"??
« Reply #1 on: March 28, 2007, 07:16:40 AM »
More fittings to me mean more places for a possible leak.  I ran a single line from the master cylinder to the caliper and kept it inside the fork tube.  Not sure what kind of clearance you have, but I used a 30 degree banjo fitting at the caliper.  I secured the brake line to the fork lower with a couple of zip ties.  Always meant to go back and fabricate a better hanger for the line, but it's been working well like this for a couple of years.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #2 on: March 28, 2007, 07:39:17 AM »
Ditch em, and go straight to the calipers...
« Last Edit: March 28, 2007, 07:41:00 AM by ProTeal55 »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #3 on: March 28, 2007, 07:42:19 AM »
What size banjo bolt fits the CB caliper?
Offline MrFry
    • T-Fry.com <--Under Construction
« Reply #4 on: March 28, 2007, 07:51:42 AM »
10x1.25
eldar
« Reply #5 on: March 28, 2007, 08:15:52 AM »
I ran straight to the caliper too. Fits just fine. I went with the HEL lines and they are slim so they run through the same places the hardline did.
Offline Chris Liston
« Reply #6 on: March 28, 2007, 10:16:07 AM »
I had initially got straight to the caliper but I had to cut about 1/8 off the banjo bolt to make it fit correctly.  I've since went back to using the hardline with proper coupler without any issues.  I'm using Russel Stainless lines.
1976 CB550F Cafe in progress
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #7 on: March 28, 2007, 10:26:53 AM »
Thanks fellas!,  I think I may have to go with the HEL's the are $30 cheaper for me in OHIO.
SOHC Member#4000
78' 550
73' CL175
Offline MrFry
« Reply #8 on: March 28, 2007, 11:05:35 AM »
where did you get the hardline. The main reason i went direct was cause i couldn't find a new hard-line.
Offline Blaize
  • Relax, God is make believe.
« Reply #9 on: March 28, 2007, 12:26:56 PM »
Go to autozone and buy a 9 inch metric brake line then bend it to shape. They cost about $5 each. Take your old one with you to match up the ends.
Living the American dream (in England).
« Reply #10 on: March 28, 2007, 12:58:28 PM »
Its the stock hardline.  Just reused it.  Doing dual disks this summer and have a complete caliper assembly with bracket/hardline I'll be reusing too.
