Author Topic: Seat Cover Procedure?  (Read 955 times)
Offline Dr. Frankenstein
« on: April 17, 2025, 11:35:56 AM »
Is there an SOP or video on here anywhere that details how to replace the seat cover on a CB550K? I've got enough seat pan to work with, but I'm not too sure how to get the dang thing on.
Offline Johnie
Re: Seat Cover Procedure?
« Reply #1 on: April 17, 2025, 01:08:42 PM »
Check YouTube. If your fingers don't hurt when you are done then it's not tight enough. I've done a few, but you need to have good foam and a good quality cover.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline jlh3rd
« Reply #2 on: April 17, 2025, 03:20:51 PM »
it makes it easier if the new cover is warmed up, let it sit in the sun.
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: April 17, 2025, 05:33:08 PM »
Very true! I also never tackle the job alone. I have a good friend that does a lot of leather work (makes custom skates for several pro hockey players) who not only has a real feel for this kind of work and fingers that work like vice grips! A box full of small bull dog clips is useful too.
Also, on two occasions I have purchased covers that were just crap. If you test fit the cover and it seems all wrong, it probably is.  I had an EBay cover for my K0 that was junk. The one from Yamiya fit perfectly and is identical to the original. It was twice the price and 5X Better. Make sure you start with excellent “parts”.
« Last Edit: April 17, 2025, 05:35:11 PM by BenelliSEI »
Offline Johnie
« Reply #4 on: April 17, 2025, 06:32:04 PM »
Agree...I also have the Yamiya red foam and cover on my KO. Exactly like OEM. Yamiya is your best bet and no surprises once you get whatever you buy from them.
« Last Edit: April 17, 2025, 06:34:31 PM by Johnie »
Oshkosh, WI  USA
Offline jonda500
« Reply #5 on: April 17, 2025, 06:35:37 PM »
Get a big box of small bulldog clips and use just them to hold it on at first so you can keep adjusting it until you have it perfect. Then permanently attach the cover working on (remove some clips from) a small section at a time before removing the bulldog clips from the next small section etc..
John
A starter clutch thread:
Offline denward17
« Reply #6 on: April 17, 2025, 07:11:31 PM »
I took my 550 seat to a shop along with the cover I bought from ebay, seems to be good quality.
https://www.ebay.com/itm/153929426581
« Reply #7 on: April 17, 2025, 08:59:11 PM »
 Those guys ^ speak truth ^
   I also get some polyester fiber sheet and use it to cover the seat foam gaps a little. I didn't use it on the last seat I did, and the cover seems a little loose.
  This time at Joann fabrics I got 2 yards because they are closing. I thought I invented the folder clip/bulldog clip method, but it seems like everyone does it.
   A split garbage bag under the new cover helps it so slide into place also.
« Last Edit: April 17, 2025, 09:15:54 PM by Don R »
Offline newday777
« Reply #8 on: April 18, 2025, 01:42:53 AM »
Den
What did the shop use for the chrome strip at the bottom?
Stu
My current rides
Prior bikes....
« Reply #9 on: April 18, 2025, 03:31:18 AM »
I'd like to know that question myself - the seat I have came with some sort of white edge-grip, or protector, but I think it would look better in silver or chrome.
Offline denward17
« Reply #10 on: April 18, 2025, 05:11:59 AM »
^I got the seat trim/buckle set from DS Spares if I remember correctly.
« Last Edit: April 18, 2025, 05:15:10 AM by denward17 »
Offline grumpy56
« Reply #11 on: April 18, 2025, 06:26:07 PM »
A hair dryer is your best friend also.
Offline Kelly E
  • Geriatric Hooligan
« Reply #12 on: April 18, 2025, 08:21:47 PM »
We use painters plastic under the new cover and have a pneumatic stapler. I have a Paul to do the stretching. We've done enough seats that I don't even have to tell him where and how much to stretch the cover. ;D
Today we recovered the 84' Honda VF 1000F Interceptor seat. A high quality cover makes a huge difference. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #13 on: April 21, 2025, 09:23:04 AM »
I've done a few, the most important thing is a high quality, proper cover or it just wont fit correctly..
« Reply #14 on: April 21, 2025, 11:41:09 AM »
There's a procedure?
