Author Topic: 72 CB750 (English) + Battery Lead  (Read 363 times)
Offline paul_nz
« on: August 26, 2025, 08:43:51 PM »
Hi, hopefully not a silly question, the positive battery lead as per attachments (Yamiya website) has additional connectors, can you tell what they are for, as I can not see what they are for. many thanks Paul
Re: 72 CB750 (English) + Battery Lead
« Reply #1 on: August 26, 2025, 09:26:25 PM »
G'day Paul. Those leads are meant for the rectifier red/white wire and the solid red wire to the fuse box, but those connections on your bike may be a ring terminal that fits onto the solenoid post?
Offline pickleknuckles
« Reply #2 on: August 27, 2025, 05:30:28 AM »
The Red from the Yamiya positive battery lead on my K4 is just an extra wire.
The Red/White splits somewhere in the harness going to both the rectifier as R/W and the main 15A fuse as R (when it exits the harness sheath to the fuse box it is solid Red).
The other side of the main fuse is solid Red and goes to the main switch.
I made a PDF of the US K4 750 diagram that isolates each color wire, should be similar to the K2 but I'd double check it against a K2 specific diagram.
« Last Edit: August 27, 2025, 05:57:18 AM by pickleknuckles »
Offline paul_nz
« Reply #3 on: August 28, 2025, 12:44:05 PM »
Thank you for your reply
