Author Topic: Quick question about smoking coil  (Read 351 times)
Offline Llanier44
« on: December 29, 2025, 01:43:58 PM »
First off, thanks for all the help you guys have provided to me. I accidentally left my key on with the handlebar control switched to “run”. I knew better. My right coil began smoking and I immediately switched the key off. There is a little melt on the wire insulation. This is a CB500.  The question is, did I ruin anything? Thanks
Isaiah 26:3
Stage IV cancer survivor (2X)
On mission to love God, love people
Re: Quick question about smoking coil
« Reply #1 on: December 29, 2025, 03:12:35 PM »
Well, it has a much shorter life at this point: when they get overheated like that they cook the enamel insulation on the wires inside, and soon it will start flaking off. The first symptoms are lower spark voltage and sometimes more power consumption, which the CB500 can hardly support.
The good news: you can get superior coils made by Sakura from PartsNmore: their part number 17-6823 is in several bikes I have rebuilt, and they work perfectly other than having a Blue wire (instead of a Yellow for one side and Blue for the other, you have to label one of them) and a Black. Their plugs are 'backward' from the Honda wiring harness, but that matters not at all: you can also just swap out those connectors (if you have some) for the opposite gender, and then everything looks "factory" again - I did this with my bike(s).
Offline Llanier44
« Reply #2 on: December 29, 2025, 05:48:28 PM »
Thanks Hondaman!!
Isaiah 26:3
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: December 30, 2025, 07:01:47 AM »
I’ve used a few sets of the “blue wire” coils and they have been working great.
« Reply #4 on: December 30, 2025, 07:20:54 AM »
Like anything electrical, once you let the smoke out its the end!
« Last Edit: December 30, 2025, 07:23:26 AM by bryanj »
« Reply #5 on: December 30, 2025, 07:50:18 AM »
Hey, I want a can of that stuff!
Offline Kelly E
  • Geriatric Hooligan
« Reply #6 on: December 30, 2025, 10:04:27 AM »
I thought Lucas replacement smoke only works on British vehicles. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
« Reply #7 on: December 30, 2025, 12:33:41 PM »
Nooooo,
St Joseph Lucas Prince of Darkness with his intermittent electron gets EVERYWHERE!!!
« Reply #8 on: December 30, 2025, 03:38:19 PM »
I think the only thing I've seen was better after the smoke was cooked from it is a new springs being made in a spring winder machine: after the wire gets wound to spec and cut off, electrical contacts nab the ends and pass power thru until it smokes, then stops. That "sets" the spring's rate, matched closely to the thickness of the steel wire. Watching automated machinery do this is downright mesmerizing. :)
That must be the evil smoke though, not the magic stuff?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: December 30, 2025, 03:46:07 PM »
I’ve never smoked coil, does it get you high?:-))
1973 CB 750 K3
10/72 build Z1 Kawasaki
