Author Topic: New from NJ USA  (Read 473 times)
Offline 86FJNJ
New from NJ USA
« on: January 22, 2026, 09:47:10 AM »
Combining two CB750 parts bikes into one bike, essentially 78F chassis with 76F engine. Seems like a very helpful forum so far!
SOHC CB750
86 Yamaha FJ1200
Offline denward17
Re: New from NJ USA
« Reply #1 on: January 22, 2026, 11:37:20 AM »
Welcome from NC!
Re: New from NJ USA
« Reply #2 on: January 22, 2026, 11:55:16 AM »
Welcome to the fun - from Colorado!
Offline Gary in NJ
Re: New from NJ USA
« Reply #3 on: January 22, 2026, 01:30:27 PM »
What part of NJ? I’m in Warren county and I’m restoring a ‘76 550F.
‘76 CB550F Super Sport
Also in the garage; ‘98 Ducati ST2, ‘05 Yamaha FZ6N, ‘81 CB900, LS650 based Cafe Racer, DRZ400 based Street Tracker
Currently restoring the CB550F
Offline 86FJNJ
Re: New from NJ USA
« Reply #4 on: January 22, 2026, 05:00:47 PM »
I’m by Ringoes a bit south from you, hope to have it running by may but if not the Yamaha is up and running
SOHC CB750
86 Yamaha FJ1200
Online newday777
Re: New from NJ USA
« Reply #5 on: January 22, 2026, 05:16:23 PM »
Welcome aboard from southern NH.
I have a 78F I'm slowly restoring
Stu
My current rides
Prior bikes....
Offline MD
  • Living in the North Woods overlooking The Lake.
    • MN North Woods
Re: New from NJ USA
« Reply #6 on: January 22, 2026, 05:56:00 PM »
Welcome from -17 F, Minnesota,
-MD
1975 CB550F Super Sport;  Lake Superior Circle 1000, 45-90 Saddle 1000, All in Yooper 1000 and SS 2000 in 48 hrs:  1985 GL1200A, MN in State SS1K
Re: New from NJ USA
« Reply #7 on: January 24, 2026, 08:20:09 PM »
Be aware that the 76 engine's sprocket mounts about 10mm further in than the 78, causing a chain alignment issue. One way to solve this is with an offset sprocket.
Online newday777
Re: New from NJ USA
« Reply #8 on: January 24, 2026, 10:40:56 PM »
Good catch
Stu
My current rides
Prior bikes....
Offline 86FJNJ
Re: New from NJ USA
« Reply #9 on: January 25, 2026, 07:10:24 AM »
Thank you! I had heard about this but am not at the point yet to get to sprockets, although I did order a 530 chain sprocket which was supposed to be for my 78 wheel but the sprocket is not as thick as the 630 sprocket that was on there and the threads to the bolts that hold the sprocket on stop slightly before the bolt would meet the sprocket, so I'm wondering if I got the wrong sprocket or if I need to add some spacers...would appreciate if anyone knows otherwise I'll deal with the sprockets in a few months when I get to that point
SOHC CB750
86 Yamaha FJ1200
Online newday777
Re: New from NJ USA
« Reply #10 on: January 25, 2026, 07:21:32 AM »
Which 530 sprocket did you order, front or rear?
Stu
My current rides
Prior bikes....
Offline 86FJNJ
Re: New from NJ USA
« Reply #11 on: January 25, 2026, 07:26:46 AM »
I ordered the rear sprocket, I had heard the front needed to be offset 10mm so I was going to wait until I had the engine back in etc before ordering that.
SOHC CB750
86 Yamaha FJ1200
Offline 86FJNJ
Re: New from NJ USA
« Reply #12 on: January 25, 2026, 07:31:12 AM »
This is the sprocket I had ordered a while back, although the pattern on mine is not circles it's probably just a generic photo, but the part number is the same except I went with a 40 tooth.
Basically once i put the sprocket on the bolts that hold the sprocket on run out of thread before they squeeze the sprocket. This 530 sprocket is thinner than the stock 630 sprocket. So that's why I'm wondering if when doing a 530 chain conversion on a 78 CB750 do I need to add spacers between nuts and sprocket or between sprocket and hub assembly.
https://www.denniskirk.com/jt-sprockets/sprocket.p81060.prd/8106040S.sku
SOHC CB750
86 Yamaha FJ1200
Re: New from NJ USA
« Reply #13 on: January 25, 2026, 09:13:56 AM »
Both 530 and 630 chain are the same tooth width, 3/8", but the pitch, the space between the pins, is different: 5xx is 5/8", while 6xx is 6/8". The stock sprockets for your bike were 15 front and I believe 42 rear, for a ratio of 2.8:1. When converting to 530 chain, a 17 front with a 48 rear will give a ratio of 2.823:1.
Do you have the '76 rear wheel? The sprocket carrier mounts the rear sprocket in closer, but I don't know if it will fit into the '78 Comstar hub.
Offline 86FJNJ
Re: New from NJ USA
« Reply #14 on: January 25, 2026, 09:45:16 AM »
Ha! I hadn't thought of that but I just checked and the 76 hub is shorter than the 78 and it does fit inside the 78 so it looks like I could use either 76 or 78 hub, I would just have to make sure the 76 or 78 spacer still work if I use the 76 hub on the 78 wheel. Although I also still have the 76 swingarm. I already replaced the wheel bearings in the 78 wheel and hub so I'd prefer to use that because  if I use the 76 I need to buy a new wheel bearing, but nice to have some options. but still prob easier to just buy a 10mm offset front sprocket if that's all I need.
SOHC CB750
86 Yamaha FJ1200
Re: New from NJ USA
« Reply #15 on: January 25, 2026, 09:18:13 PM »
If the '76 sprocket carrier fits the '78 comstar hub, that's the way to go. ;D The '78 swingarm is wider on the chain side, so the '78 spacer should work; it's easy enough to check. This will allow you to use standard '76 sprockets instead of more expensive offset sprockets. Fitting the '76 swingarm to the '78 frame presents another issue, since the shock is also offset on that side.
