Author Topic: Easy Spring Removal  (Read 4426 times)
Offline jrrobertsjr
  • If you aren't scared, your not going fast enough.
Easy Spring Removal
« on: April 16, 2007, 05:38:03 PM »
I was stripping a frame today and shot a quick movie cause busted knuckles suck.
http://www.tonuphouston.com/images/carbs/Spring_Removal.wmv
Johnny
Re: Easy Spring Removal
« Reply #1 on: April 16, 2007, 07:39:03 PM »
That is amazingly clever. Thanks for sharing. I think that may work on other coil springs also.
Offline francisew
  • Francis
  • Francis Esmonde-White
    • Esmonde-White.com
« Reply #2 on: April 16, 2007, 09:07:41 PM »
Very cool. I guess as long as it goes back together fairly soon, it shouldn't cause damage to the spring?
Francis
Offline mrbreeze
  • Not your average
« Reply #3 on: April 16, 2007, 09:15:52 PM »
Looks to be more time consuming than levering it on but whatever gets the job done (I guess).
MEMBER # 257
pyro139
« Reply #4 on: May 21, 2007, 10:25:58 PM »
inginous thank you, i need remove side stand to shore it up cause lowered bike, and to clean it, going electrolize side stand polish then put a coat of clear engine paint.
Offline Johnie
« Reply #5 on: September 13, 2007, 07:27:49 PM »
Nice idea.  I just use a coat hanger with the stand up and pull it off.  But thanks for a nice idea.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline edbikerii
    • Gallery
« Reply #6 on: September 13, 2007, 08:09:52 PM »
A guy named _biffta_ had a really good method for putting the centerstand spring on without any tools whatsoever.  You just connect the spring to the frame, and then the centerstand, and then just put the centerstand in place by hand while levering it against the spring.  Much easier than the coins, and less risky than the "brute force method" of muscling the spring into place.
Here's the link:
http://forums.sohc4.net/index.php?topic=18571.msg194104#msg194104
« Last Edit: March 16, 2011, 04:37:26 AM by Glenn Stauffer »
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
